Question about Kenwood KVT-512 Car DVD Player
KVT-512 reverts to "CALL" screen.
Anytime I start my truck and even when driving, this deck goes to a call screen and I have to go into sources and reselect my desired source. It is pretty anoying as it sometimes will do this 3 times in a 5 minute period. By call screen I mean it says call on the top left corner of the screen and nothing else. Yes this has bluetooth setup and it works flawlessly and this screen came up from day one with this deck when the bluetooth wasn't even installed.
In your wiring harness there is a brown wire posbily. I ran into a similar problem on a newer Chrysler vehicle. Make sure that brown in NOT hooked up and you should be ok.
Posted on May 10, 2009
My deck is looked & i don't have the code is thare a way to unlock it?
is your deck a remote control operated? you can use it if you have.
Aug 25, 2010 | Kenwood KVT-512 Car DVD Player
I had to change my battery on my truck and when i did my kenwood kvt-512 flip screen says protect and will not play any music... help please...
It might have taken a small short. You can push the reset button just to the left of the volume buttons. Good Luck.
May 29, 2010 | Kenwood KVT-512 Car DVD Player
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
May 14, 2010 | Kenwood KVT-512 Car DVD Player
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
How do I change the background on my kenwood kvt-512
Check one DIY in this link: dyi-background-change-kvt-512-a.
Hope helps (remember to rate this answer.
Nov 18, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 with bluetooth setup troubles
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Mar 02, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 Car DVD Player Logo
110 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
