Question about GE Washing Machines
Water squirts out of the top of the tap hookup on our portable spacemaker
  • GE Master
  • 17,130 Answers
Possible there is a block which makes the water to leak out. remove the inlet connection and check the free flow, check the inlet filter and the valve, check the connectors for right mating. If there is leak then you must use teflon tape to plug the gap on the thread
Posted on Jan 12, 2013
I have a 1984 holiday rambler how do I hookup city water I have three hookup s two that are together and one by itself
guessing here
one would be to the fresh drinking tank
leaves two to choose from
does the RV have two types of taps ?
how many water tanks on this model ?
have see one layout with chemical toilet and normal house taps at its sink
or kitchen sink with multiple taps
Jun 22, 2016 | Holiday Rambler RVs
Do i have to turn water off to disconnect a washing machine
normal practice plumbing is to connect the machine hoses to the wall taps
unless you have something different ,turn the taps off at the wall and unscrew the hoses
if your practice is to leave the wall taps on all the time ,when you start to undo the hoses there may a bit of water squirt out as that will be the pressure still in the hoses
Apr 22, 2015 | Washing Machines
Loud noisy boiler what's wrong with it ?
Hi. I'm not an expert but most of my boilers in the past get noisy when they get air in the system. Underneath your boiler will be an inlet tap to top up the sysem with water. Make sure you bleed all of your radiators of air till they squirt water then keeb topping up the system and bleeding till no air remains in any of the radiators. There should be a pressure dial on the front of your boiler and there is usually a red fixed needle which shows what the opperating pressure is. I would do this before anything else and see if this solves the problem. :-)
Apr 29, 2013 | Water Heaters
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
Water Supply
The ice maker hookups are typically located at the bottom of the reverse side of the ref.
You'll want to have enough slack in your supply line so you can roll the machine forward to clean, and service the machine while still leaving the water supply attached. So if you leave enough extra tubing on your supply line, you'll be ready for where ever it's located on the unit.
If you don't have water to the ref's location, you can purchase a complete icemaker hookup kit with a saddle self-tapping valve, copper or plastic supply line and the necessary fittings. This is typically tapped in to the cold water supply under the sink or on a cold water supply line under the house. If you run it thru cabinets or flooring, I recommend using the copper supply line.
K
Jun 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Installation of washer/dryer combo with no taps available
hello you can buy washing machine taps that screw on to the main water pipe. what to do is turn your water supply off at the stopcock and get the your new tap and clamp it on to the water pipe and tighten it up.it will make a hole into the pipe and to the same with the other 1 when your done turn water supply on make sure you have no leaks good luck
shaun
Mar 28, 2009 | Haier HWD1000
GE Spacemaker Extra-Large Capacity Portable Washer
i was using a defective extension cord, the machine should trip when start it . and beep with no other message on the screen
Nov 08, 2008 | GE Spacemaker WSLP1100D Top Load Washer
HOSE PARTS?
If you mean external hoses between tap and washing machine, and washing machine and waste drain to install the washer in place. Everywhere. even the local hardware store, those items are a standard size, thread, and diameter and fit all washers.
if you mean the click fit hose to a sink tap, with the waste water drain buldled in so the washer can remain portable
Sears has them as a to-order item and most parts stores will have a generic brand that will fit straight on, the screw fittings are standard.
Aug 08, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Washing Machines Logo
23 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
