Question about Acer Aspire 5500 5570-2609 Laptop
BROKE OFF THE POWER ADAPTOR PIECE INSIDE LAPTOP
HOW DO I REPACE THIS AND WHAT PART DO I REPLACE
  • Acer Master
  • 32,281 Answers
You maybe ale to remove the broken plug with a pair of tweezers or a needle nose pliers.
You need to buy a plug, the same size os the one you have removed then you can solder this to the leads on your power adapter.
Make sure the leads are soldered to the plug with the correct polarity if it is wired the wrong way it can damage your laptop.
Posted on Jan 12, 2013
Peg for plugging in power adaptor
HELLO!!!
JUST A SEC I"L GET U THE INFO!!
Mar 01, 2008 | Balance CN6555 Notebook
My girlfriend dropped her laptop today (Medion Akoya P6613) and it landed on the power adaptor that goes inside. When she picked it up the power lead fell out and there is a rattling noise coming from...
the piece inside is cheap in cost for my hp about 20$ a good repair guy should get you running for less then 100$ for everything shipping new piece and he repair included good luck not sure how easy it is to get a tech in iceland
Dec 20, 2010 | Computers & Internet
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Cant use my adaptor
this seems to be a common problem. I have some experience soldering, so I opened up the case and replaced the part with a Radio Shack DC jack, soldering the tabs to the motherboard with insulated wire.
If you know someone who can solder, this isn't that hard a fix, once you figure out how to open up the case (in addition to the screws visible outside the case, there is one underneath the keyboard. Remove the faceplate over the speakers/HP Now buttons, then you can remove the keyboard.
Oct 12, 2009 | HP Pavilion ze4125 Notebook
Adaptor broke off
It wolud require a new tuner as trying to fix this part back in normally does not last or if the end tag piece is too short to re-solder back on then the part needs replaced. You could try getting a local repair shop to give you an estimate on the cost before condeming the TV.
Sep 27, 2009 | Sharp 13VT-N100 Combo
Inpspiron 1525 dell
It's probable you're inadvertently touching the touchpad with another part of your hands while you're typing. There's a setting in the touchpad configuration where you can choose to sort of disable the touchpad while typing. Regarding the trouble keys, there are keyboards that come deffective from the factory. The one I'm using this moment has that problem with just two keys, reason why I can still put up with it! If your notebook is still under warranty, call DELL and arrange service for it.
Aug 16, 2009 | Dell Inspiron 1501 Notebook
Power cord/AC Adapter
Unless your have some technical background and a multimeter, you are risking at least the battery pack of your laptop and worst case, the laptop itself.
Most devices that accept an external adaptor are somewhat protected against applying the wrong polarity of voltage but that protection is primitive and depending on the 'universal' (this really should be 'multipurpose-not 'universal) adaptor used, the protection itself can fail, exposing the circuitry inside the laptop that controls the voltage from the adapter to damaging voltage; this would get much more expensive than replacing the original adapter from the manufacturer of the laptop.
You did not mention the brand/model of laptop you have and with only the adapter listed, we can't help you much.
Mar 17, 2009 | Radio Shack Accurian APD-3955
Melting power adaptor
Is the power adaptor made for the country you are living in? It's possible the plug you are plugging it into has a higher current than the plug was certified for. Have you tried plugging the laptop in in another location (like, in a different building)? You may just need to replace the adaptor, how old is it?
May 01, 2008 | Gateway 7405GX Notebook
Connection overheating
If it is the external adapter that is overheating and stopping after a while yes, replace it immediately. Fact that power adaptor is overheating means that there is a short inside the adaptor, this may damage the laptop, then change it as soon as possible.
If the laptop itself is overheating, check if the cpu fan is working, and eventually replace it.
regards
Mar 19, 2008 | Dell Inspiron 2200 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
15 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
