Question about M2K Garfield: It's All About Math-1st Grade (GRF8AM201) for PC, Mac
Show me my IP address
Please show my ip address asap
    Problem Solver:
  • 5 Answers
If you need to find out your internet IP, You can find it out by visiting www.IP-Details.Com It is very simple. Cheers mate.
Posted on Jan 15, 2013
2 Suggested Answers
  • 6 Answers
SOURCE: good evining....,i dont want to show my ip address?
If you have a firewall and anti-virus, there's no reason not to show your IP address. Unless you use a proxy, if you're on the internet, your IP address can be seen. Any website you go to can see your IP address. But as I said, with firewall and anti-virus, nothing at all can be done.
To hide your IP address, you can use a proxy. If you use firefox, take a look at this link.
http://technicalbliss.blogspot.com/2007/04/how-to-use-free-proxy-with-firefox.html
Using proxies hides your real IP address.
http://whatismyipaddress.com/staticpages/index.php/how-do-I-use-a-proxy-server <--- This is another very helpful link.
Posted on Dec 27, 2008
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
My Cisco IP 7960 Phone is stuck at "configuring IP"! What is happening? I need to get it fix asap :(
it would appear your phone is not getting an address from your DHCP server, i would start by plugging in a laptop to see if that gets an ip address
Hope this helps
May 21, 2011 | Cisco 7940 IP Phone
How to configure internal LAN in B-SX4T barcode printer?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
May 05, 2010 | Toshiba TEC B SX4T Printer
Cannot acess ip address
HI! you can access the ip address of your router by connecting it directly to your computer.. if you are using a windows xp operating system. use your mouse and click on start and select run, from there it will show a box and type in on the box cmd and it will show you a dos prompt and from there just type ipconfig /all and it will show your ip address..
Jul 19, 2009 | Computers & Internet
IP address Problem with Dell Studio 1525
Most probably its the problem with the autonet ip address where the computer picks a bad ip address. If your internet service provider has DHCP enabled you cannot put the manual IP address. If its a new problem try system restore, uninstalling and reinstalling networkdrivers. resetting winsock.(search google)
Mar 30, 2009 | Dell Inspiron 6000 Notebook
How to find ip address
hi,
cliakc on start button > run > type in without quotes "cmd" > ok(run) > click on the black window > type in without quotes "ipconfig"
this will show your ip address
Further Queries are welcome
If you find my solution helpfull please do rate me
Mar 17, 2009 | Dell Inspiron 1525 Notebook
Good evining....,i dont want to show my ip address?
Dec 24, 2008 | M2K Garfield: It's All About Math-1st...
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
M2K Garfield: It's All About Math-1st Grade (GRF8AM201) for PC, Mac Logo
528 people viewed this question
Top M2K Computers & Internet Experts
David Payne
David Payne
Are you a M2K Computer and Internet Expert? Answer questions, earn points and help others
