Question about Dell XPS™ 600 PC Desktop
XPS 600 - Six Beeps No Boot
When I turn on my Dell XPS 600 I hear 6 beeps from the computer and no signal to the monitor. This comes after it recently has been rebooting randomly whether I'm actively using the machine or letting it idle with processes such as Firefox running.
  • tsion_cy Jan 30, 2009
    Yes, your response sent me on the right track to solving my problem. Initially I was trying to help fix that computer over the phone. Once I got it in my hands it was just a matter of eliminating potential issue. I came down to little more than "6" beeps that I was told over the phone. In the end though it led me to a memory problem that was caused by the motherboard. It stopped working with Dual Channels. Instead of running on the single stick of RAM (which allowed me to boot) I stuck the the two in slot A1 and B1 so it at least kept the same amount of memory.
    Master:
  • 413 Answers
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Posted on Jan 22, 2009
  • Dan rogers
    Dan rogers Jan 26, 2009
    i just wanted to check in and see if I was any help to your problem?
  • Jason Tennant
    Jason Tennant Oct 27, 2013
    mine has done this a few times, usually just unplugging power supply lead from pc, then holding down power button to remove static energy and then plugging back power and rebooting solves this issue. Once this has failed then i just removed panels and hoovered out motherboard and componants seemed to do the trick
Dell xps 600 will not display any picture at all, beeps six times lights 2 and 3 are lit on front diagnostic display. Replaced memory with working ram from another pc, replaced pcie graphics card with...
sounds like youv'e covered all the possibles i would. could be the boot files got corrupted or the monitor is bad(have you checked it with another pc?) check the motherboard for swollen capacitors(those barrell looking objects randomly scattered over board. if the tops that have little crosses on them (+) are popping up/out unlike others, then your board needs replacement or new pc. cannot fix those. happened to a friend of mine. would not boot up to show windows.
Nov 03, 2013 | Dell XPS™ 600 PC Desktop
Dell XPS 600 turns on, However does not boot. Screen is black....
Do have windows installations disc put it computers cd reader.if windows when windows start from the disc choose to repair go back in time before the accident.
Mar 30, 2013 | Computers & Internet
Beep codes on dell xps one 2010
If I understand your issue, it sounds like the display works fine until it loads Windows, and then it has the error? It sounds to me like the video card drivers are crashing. This may be the case if you have recently updated them, or installed a new video card. I would recommend getting the latest drivers from the manufacturer's website on a CD, SD card, or USB drive, and then boot your computer in safe mode. Once in safe mode, install the new drivers, and see if that will help. You could also try using your onboard (integrated) video card if your motherboard has one. This could help rule out if the monitor is at fault. Just make sure your BIOS has the integrated card as a secondary video device if it the (I'm assuming PCIex16) peripheral card isn't found.
Oct 06, 2012 | Dell XPS One All-in-One TV Desktop with...
When i turn on dell xps 600 i have 2 shot beep and system never come up. Any idea . Thanks you.
Its a biosPOST error code:
For more info and details, click here:
Jun 09, 2011 | Dell XPS™ 600 PC Desktop
Monitor looses signal after being on stand by for a period of time. Have to reboot the computer. First reboot unable to establish connection and sounds in repeated short beeps in sets of 2 .Have to reboot...
You have a problem with video adapter. First try to remove it from the slot and clean the conector with a rubber. If problem persist you have to replace adapter.
Mar 23, 2011 | Dell Studio XPS PC Desktop
Dell XPS 600 beeping noice
there are 2 things that can cause that, memory failure, or mother board, cheeper route to go would be replace your memory first, and see if that corrects the problem, if not then, check anything new you installed inside such as video card, lan cards, of something like that, if that doesn't work you need to have it looked at and possibly the mother board replaced,
Jun 22, 2009 | Dell XPS™ 600 PC Desktop
I have a Dell XPS 400 with Microsoft XP. It recently shut down with a Blue screen stating that a recently installed driver is possibly bad. I was able to restart the CPU after a while and with in a few...
don't reboot instead reinstall the windows may solve this problem.i recommend ur xps laptop use windows vista ultimate because its have great performance i heard.
Jan 15, 2009 | Dell XPS 200 PC Desktop
Dell XPS fan come on but nothing else powers up. I hear a beeping noise coming from the PC.
most likly a hardware issue i would recomend taking it into a shop what is your computer experience?
Jan 08, 2009 | Dell XPS™ 600 PC Desktop
Monitor will not start
So, when the monitor is on, connected to the wall (not to the computer), there's absolutely no signal? no message on the screen? no colors moving? Have you tried with another power cable? You can try this test. Use the computer's cable to test if the problem is the monitor's cable.
Nov 19, 2008 | Dell XPS™ 600 PC Desktop
Random Power Loss on Dell XPS 600
Possible reasons for random rebooting:
1. CPU Fan/Heatsink is loose Restarting due to Overheat Prevention. Im guessing the processor is LGA775. if u can open up the case and see if any of the four plugs and sockets has come loose, then that might be it.
2. Not Enougth power from PSU (Power Supply Unit). if it was built for gaming im explecting a PSU of at least 750Watts
3. Harware malfunction. When booting up, any error beeps?
4. Software error. Before logging in a user account, leave the computer on for a while if nothing happens then most likely be OS problem.
Your best bet is to reinstall Windows
Oct 07, 2008 | Computers & Internet
Dell XPS™ 600 PC Desktop Logo
2,860 people viewed this question
Alun Cox
