Question about Goodman CLJ30AR32 Air Conditioner
Tstat wiring touched together and cant find fuse
  • kiddkerr73
    kiddkerr73 Jan 22, 2009
    goodman ar32 no fuse that i can see, tested the wires inside on transformer,the power stops there,wonder if i fried that,or maby the power stops at the transformer because the tstat is not hooked up to tell it to,no what i mean sir? thank you for getting back
    Scholar:
  • 144 Answers
What kind of system do you have? The fuse is usually located on the circuit board inside the furnace/air handler. It's probably a spade type and would be either amber or purple. 3 or 5 amps.
Posted on Jan 22, 2009
  • Perry Putnam
    Perry Putnam Jan 22, 2009
    If you have power to but no 24 volts from the Transformer then yes you fried it.
On a good man air handler aruf61d14aa model we have trouble with low voltage wiring. Already blew one fuse so thinking I have wired it wrong.
Red is power green (or in a goodman might be grey) lands on g which is for your indoor blower white is for heat. Yellow from the tstat( which doesn't land in the air handler ) is for cooling and goes out to the condenser along with the blue which is common. First unhook all your tstat wires. Put red and green together to turn on blower. Turn power on and make sure it's good. Then add white for heat, turn power on and make sure you're good. This will ensure YOUR PROBLEM IS OUTSIDE the air handler. Then ONE WIRE AT A TIME add back your tstat wire, turning power off and on after each wire. First do red. Then do green then do white then do yellow. TURNING POWER OFF EACH TIME. IF AND WHEN THE FUSE BLOWS you will know what part actually blows the fuse. Let me know. It's possible your contactor outside is shorted and blowing the fuse. This will blow the fuse only when you hook the yellow from the tstat up to the wire going outside to condenser. Remember to unhook everything first. Let me know if you need more help.
Jul 30, 2017 | Heating & Cooling
Inside fan does not blow on auto or fan only.outside ac will work if i push in the relay switch
So you have no 24 volts. Either float switch is tripped, transformer or fuse bad, or your tstat is bad. Turn power off to indoor unit. Open tstat and wire red green and yellow together. Turn power back on. Let me know...
Jul 04, 2017 | Heating & Cooling
How are the wires connected from intertherm thermostat to nordyne E1EB-015HA unit
There's probably about 10 different ways to wire them together. If rh & rc where jumped together an tstat then R-RED W-WHITE G-GREEN Yellow (from tstat) to Red to outdoor unit if that's what they had connected outside(should be a red & white outside). If rc & rh were not jumped together @ tstat? The unit has 2 transformers and its a bit different. Rh is 24v from the inside and rc 24v from outside. And also we can use any color we want so who knows what the last guy used. Try this, install the new tformer and at the line voltage wire(L1 or load wire) get a couple of spade connectors(terminal clips) and put one on the tformer and one one the line wire. Then use a 3amp or 5amp blade fuse(auto parts store) and connect your line voltage wire end and tformer wire end to that fuse. But don't let them touch metal or each other. And buy a handful of them fuses(no greater than 5a!!). This protects the tformer as long as its done right. Then reconnect what you remember to be right or just connect 1 wire at a time. Try fan on and cool or heat, 1 wire at a time, and if the fuse opens you know that one is wrong. There is no way you can get the answer you need without knowing what wires are connected to what inside, outside and at tstat. Hope this helps and WORK SAFE!!!
Jul 29, 2015 | Intertherm Heating & Cooling
THERMOSTAT WILL NOT COME ON.
You may have missed the fuse. It will/should be part of the control board and has a 3 or 5 on it. You can jump R to G at the tstat by touching them two together. If you don't feel comfortable doing this then don't do it. G will bring on the fan only. And if it starts then you probably have a bad tstat. If not, then you have a short that damaged your 24volt transformer, or lost power to the whole unit. Check your breakers!
Mar 10, 2017 | Heating & Cooling
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
I set the tstat to cool everything ok i set tstat to heat it blows the fuse on pc board
Check for wires rubbing together from the thermostat to the furnace. More than likely there is a short somewhere in the low voltage wiring. Check the wires on the thermostat also to make sure none are touching together.
Apr 11, 2011 | Goodman CACF048B2A Air Conditioner
3 ton carrier split unit heat&cool,mod#38QH036300DL, Heat is good, thermostat will not shut it off. only way to shut the inside unit off is turn off the circuit breaker
Sounds like a bad tstat. The Tstat does control the on and off of the unit.
You can check the Tstat by taking off the white wire to the tstat and turning the heat to the on position and if it still comes on you have a bad wire. If it does not come on then you have a bad tstat.
Another option is to open the furnace and look inside at the control wires and follow them back to ensure that they are not shorted together anywhere inside the unit before checking the tstat wires.
If its the control wires then follow option 1 if not follow option 2.
1.Normally people who run tstat wire pull more wires than necessary to the tstat. Because of this you can use a different one for the heat which is white on the tstat. Remember that if you use another color on this then you need to change it on the inside unit as well. Otherwise it will not work. In other words change it on one end of the line you have to change it on the other to make it work.
To check the tstat wires, use continuity. Take all the wires off the tstat and the inside unit. These are the small control wires, not the main 110 wires. Check each one against each other to see if any of them are shorted together. Be sure to write down the wire colors and the terminals that they belong to on both sides before you take them off otherwise you will have big problems...
If you do not have another wire then pulling a new wire will be the next option.
2. If this does not solve it, then its the TSTAT, Replace it. Hope this helps.
Jan 28, 2011 | Heating & Cooling
Dryer functions but no heat; only cool air
unplug dryer and gain axcess to back of dryer and remove back wall plate look at lint shute bulkhead housing their will be one thermostat with four wires and one white plastic fuse safely remove the wires off fuse and tape together for testing only ...... make sure cover with electrical tape now make sure wires dont touch anything meatal no plug in dryer and check for heat if dryer starts heating goahead and order new fuse and replace thermal fuse ,,, and clean dryer venting and check for any kinks in vent pipe ........ if that test didnt produce any heat replace heating element its in aluminum duct on right side of the back of dryer ...... their is also a high limit tstat on the upper left side of this duct you can jump this out for testing only and check for heat aswell donot operate dryer with these jumped out except for testing theses are safety precautionary thermostats,,,
Jan 28, 2011 | Whirlpool LER4634J Electric Dryer
Tstat wiring
Thanks for your Question,
one of two possiblities, first and most likely is that you have blown the Transformer in the Furnace, second would be that you have blown the small car fuse that is on the circuit board in the furnace, if you look really hard you will find it, it looks like an automotive fuse, should be about three amps, if it is the fuse, then its a simple fix, make sure the power is off, replace the fuse, if its the transformer, a little more involved work is needed, but still should be pretty straight forword, and again, please make sure the power is off when replacing, hope that helped ! please be sure to come back and let us know how I did for ya, thanks again,
mr.grzz
Jan 22, 2009 | Goodman CLQ36AR49 Air Conditioner
How to wire 1 plf 1504d heater
I have the solution, finally after looking for 2 days.
First off, I couldn't quite put it all together based on what I was reading. I finally tracked down the Fahrenheat web site (www.fahrenheatpro.com). And called tech support (800) 452-4179.
To wire 2 BB units to 1 tstat.
1. Use #14 wire for 0-12 amps, #12 wire for 12.1 to 16 amps and #10 wire for 16.1 to 24 amps.
2. I have a 12/2 wire going from the tstat to BB#1 and another 12/2 wire going from BB1 to BB2.
3. Onthe left side of the heater, you will have 2 sets of black wires tied together with a nut (on right side it's 2 sets of Black/Red wires). You can use either side of the heater. For the purpose of explaining this, lets use the left side, 2 sets of black wires.
4. Undo one of the sets of black wires (it doesn't matter witch), the other set will be left alone.
5. Take the black wire coming from the tstat and tie it into one of the black wires from the heater and the black wire going to the second BB unit. So you will have those 3 wires tied together with a nut at the 1st BB unit.
6. Take the white wire coming from the tstat and tie it into the other black wire from the heater and the white wire going to the other BB heater. Again, you will have 3 wire tied together here.
7. At the second BB unit, tie the black wire coming from the 1st unit to one of the black wires in one of those 2 sets of black wires. Again, only undo 1 set of wires at the 2nd unit, leave the other one alone. Tie the white wire coming from the 1st unit to the other black wire.
8. Make sure ground wire in grounded at the tstat and at both BB units.
Hope this helps...... If I was less clear than I hoped, call tech support and they will walk you thru it....
Kevin.
Dec 08, 2007 | Fahrenheat Electric Convector Baseboard...
Goodman CLJ30AR32 Air Conditioner Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
