Question about Epson 1000 ICS All-In-One InkJet Printer
Printer makes noise while cleaning heads
I own a used Epson 1000 ics all in one printer which has always given me good service. The other day the ink monitor indicated the black ink cartridge was almost empty . So I decided to replace both black and color cartridges. Then I find you usally have to clean the prints heads about three times before you get a good test page printout. I found that when I clicked the clean button, the printer makes a loud clunk, and as the cartridges move to clean the jet nozzles the printer make these really upsetting grinding noises, it really sounds like the printer is tearing it's self up. After I did a few of these grinding nozzle clean sessions, i did a test print, and found that the black ink, and yellow printed fine, but cyan, and magenta didn't. The printer made no unusual noises. and prints documents in black just find, but don't dare and try and clean the heads and you get all the grinding noises. I really need avise on how to correct the gear grinding noise Yours Truly WILL - C
  • LiteJazz53 Nov 07, 2007
    I have the EXACT problem. When the printer goes through the cleaning process, it sounds like it is destroying itself. What is worse, with brand new cartridges, I get NO printed information on the page, nothing prints,a dn I mean nothing, a blank white page. I have tried allignment, tried cleaning many times, and the cartridge is just going empty. Epson says the ink is dumping in a sponge and I would not see anything on the paper!
    What is clogged up, and darn it, how can I get it unclogged, where something, anything will come out and print on the paper,
    Help Help!!!
    LiteJazz53@yahoo.com
  • Epson Master
  • 691 Answers
Grinding noise is most likely caused by the carriage lock getting stuck and holding the print head at the home position. The noise is caused by the toothed belt that pulls the head back and forth, skipping over the splines on the motor drive wheel. If you have been able to print since the problem occurred, chances are that it has freed itself up and will be fine. Regarding the loss of cyan & magenta output, follow the solution given in my previous posts to complete a manual under-head cleaning cycle. This should get you going. Check this previous post for cleaning info: http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Posted on Jul 05, 2007
Grinding noise after changing cartridges
When you put new carts in, it will then clean the print heads. There is an unbuilt system for this in the printer, it will purge ink through the heads to clean them. It does make funny noises sometimes.
Sep 05, 2012 | Epson Stylus Photo 1410 Printer
Tip
Print Head Cleaning Cycle
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
Use the Printer Driver Utility to clean the print head. Alternatively, try this SSC Service Utility.
Also try changing the affected ink cartridge.
All else fails, your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
on Jun 15, 2008 | Epson Stylus Photo 1280 InkJet Printer
I have had my Epson R1900 since last July, and it has worked just fine for me up until a couple of months ago when it began printing with a very noticeable blue-green tint. I always use Epson 87 inks, and...
using your printer once a week makes your printer clog even if you use original cartridges i prefer using it once a day, if you dont have anything to print, just turn on your printer and it will automatically head cleaned its head
May 24, 2011 | Epson R1900 Printer
My Epson printer is printing blue lines (like ruled paper) when printing text.
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 10, 2010 | Epson Office Equipment & Supplies
Epson 1000 ics printed picures streaked
try this
- print at slower speeds
- run the cleaning utilities(program) that came with you printer.
Mar 26, 2009 | Epson 1000 ICS All-In-One InkJet Printer
Head carriage stays left and grinds
Did you check to see if the ink was low in the printer? Epson wont let you print if the ink is low, happened to me before!
Oct 22, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epsom cx3200 off brand ink refill
Make sure the print head nozzles are not clogged. You may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
When you don't turn on your EPSON CX3200 for a long time, the print quality can decline. It's a good idea to turn on your EPSON CX3200 at least once a month to maintain good print quality.
1. Make sure the EPSON CX3200 is turned on but not printing, and the Error light is off.
If the Error light is flashing or on, you may need to replace an ink cartridge.
2. Press the left Menu button on the control panel several times until you see Cleaning and then press the Copy button.
Cleaning takes about 30 seconds, during which the EPSON CX3200 makes some noise and the Operate light flashes. Never turn off the EPSON CX3200 while the Operate light is flashing, unless the EPSON CX3200 hasn't moved or made noise for more than 5 minutes. setViewedFAQCookie(14082, 31605);
Oct 02, 2008 | Laser 3115cn All-In-One Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson rx 500 print problem
3. Click on START.
Jan 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Nothing Prints on the page
the print head needs servicing or you can try checking out this link : How to Unclog Epson Print Heads
Nov 07, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Epson 1000 ICS All-In-One InkJet Printer Logo
391 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
