Toshiba TV model 19A24
Lost manual - trying to find out if this TV is digital or analog since even with cable analog signal will run out in 3 yrs.
    Sergeant:
    Champion:
  • 267 Answers
THAT IS AN ANALOG SET. YOU NEED THE CONVERTER BOX. FOR TRANSITION TO DIGITAL.
Posted on Jan 22, 2009
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
When I hook my tv up to cable I get no signal, if I just hook it up with antenna it works fine. How do I get my tv to work with my cable cord? Would be nice to view cable channels instead of just 3...
nialbert,
It sounds like you are hooking the cable to the wrong input (digital instead of analog) or you do not have an analog input. If you do not have an analog input you could run the cable through a VCR to convert the signal to a separate audio/video signal and send it to the TV via an auxillary input. Without the model number I can't give you much more help.
Thanks for using FixYa and for the great rating.
hardrocko
May 09, 2011 | Televison & Video
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
My Sony AV unit (probably 3 yrs old) suddenly switches from all 5 channels to just the two front without warning; I can push enough buttons to return it to all 5, but sometimes it switches back and forth...
You don't name the model but if there's asettign for audtomatically selecting digital vs analog when both are attached it's losing the digital signal and automatically switching to the analog feed. Find it in the manual. lacking a setting, it prefers digital over analog and will switch to analog on digital signal loss.
Analyze what source(s) are involved and investigate WHY you're losing the bitstream. Optical cables must be run with smooth loose bends so the light strength is not compromised.
Feb 04, 2011 | Sony A/V Receiver
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Tv picture
It seems to me that you are watchin an analog signal on a digital HD TV, the analog signal is has a standard resolution of 720x576 for NTSC (American Signal) and 720x480 for PAL (European Signal).
It could be worth to go contact your cable company, they can hook you up with a digital receiver which gives a better signal and might even have a HD Signal (this means it has a HD-Ready 1280x720 of Full HD 1920x1080 resolution).
If you really want to use your LCD TV on his max this is really worth considering
Jan 30, 2008 | Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
