Question about HP Photosmart M307 Digital Camera
Problem with HP digital camera. Urgent. please help me out
Hi, My Hp camera turns on but none of the buttons wotk after that.I can take pictures, but cannot even view them. I can't even turn it off. My warranty period is over. Please help me out.
    Genius:
  • 2,985 Answers
Do get onto HP Tech Support. It may be a fault they will deal with out of warranty- certainly they will know about the problem
Posted on Jul 05, 2007
How do you turn the flash off on a hp photosmart 435 camera
Hi hookerglen.
NOTE The flash does not work while recording video clips.
To change the flash setting, press the Flash button on the top
of the camera until the desired setting appears on the Image
Display. The camera remains in the current flash setting until
you change it or turn off the camera.
please fellow the instructions in the picture bellow aid you use your hp cameras flash light better.
let me know if it works for you.
Thanks.
May 11, 2011 | Cameras
Hp 537 photosmart camera. my picture is frozen. i can,t access my previous pictures nor take any other picture. camera will flash but no new pictre is shown. please help.
Try to reset the camera - take out the battery then push the reset button with a straightened end of a paper clip. Hold the reset switch depressed for about 3 seconds. Reinsert the battery.
Sep 28, 2009 | HP Photosmart R707 Digital Camera
My camera will not take pictures
It cant be fixed
It is a firmware failure.
Replace the camera
Dec 18, 2008 | HP PhotoSmart M627 Digital Camera
Big fingers and need it simple
Tammy,
The HP PhotoSmart E317 is indeed a simple to use camera. Here's a picture of the back of the camera. TestFreaks gave it a 6.0 out of 10 -- from the experts. However, real users (consumers like you and me) gave it a 7.9 out of 10. There are very few buttons to deal with and the open/close door acts as the power off/on function. It should be a good replacement for your older camera.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | HP Photosmart E317 Digital Camera
Upload pictures to the hp photosmart 435 digital camera
You can do it through Windows Explorer.
Plug in your camera via USB cable to PC. Make sure it gets detected. Right click on the START button and select Explore. In the left hand pane, if you scroll down, you will see your camera listed as a drive (usually after the DVD/CDROM drive). Click the (+) next to the entry to expand the folders. (Copy the images you want to import into the camera from the PC location first). Now simply locate the folder in your camera drive that stores pictures, right click and paste them.
Please take a moment to assign a Fixya rating if you found this solution helpful.
Jun 02, 2008 | HP Photosmart 435 Digital Camera
Continuous flash charge
Try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 23, 2008 | HP Photosmart 735 Digital Camera
Olympus FE 190 pictures are blurry
Check any adjustments that have to with resolution. Do they look more pixellated when you look at them on the computer. Or do the pictures look out of focus?
You should check under the Shooting guide #3 (blurring background) to see if this helps you.
If none of the settings (ISO settings, resolution, lighting, image stabilization mode) help you, contact HP next.
This camera, if I recall correctly, is a fairly basic camera. I would contact HP and see what they can do for you. Since the camera is close to the warranty period of one year, they should cover it under warranty.
Mike
Nov 12, 2007 | Olympus FE-170 Digital Camera
Sandisk 2Gb card not registering PLEASE HELP?
1sr Check the manual- It is possible the the 2 Gb card is too big for the camera.
If it is acceptable to the camera then the card is probably defective and needs to be returned for exchange.
Nov 08, 2007 | HP Photosmart E327 Digital Camera
Keeps saying memory is full
My name is Vikram Kumar Thumu, from India-Hyderabad. I have seen your message on the issue related to error message  that " Memory is Full "  . I would like to provide my suggestions on the issue. I hope that this should work for you and will resolve the issue.
I guess that this could be your error message " Card full
or Memory full". The possible cause could be Insufficient room in internal memory or on the memory card to save more images. To resolve the issue please unload images from the camera to your computer, then delete all images from the memory card or internal memory. Or put a new memory card in the camera.
Please try to Power Reset the Camera once,  I hope this could work on AF flashing issue.
Steps are:
Resetting the camera can correct many issues, such as the camera locking up or not turning off. The reset drains the power and, in some cases, causes the camera settings to revert to factory defaults.
NOTE:
Resetting the camera returns all settings to the factory defaults. Any images or video clips stored in memory are retained.
Perform a power reset of the camera
Follow the instructions below to reset your HP Photosmart camera.
  1. Press and hold the Power button for 10 seconds.
  2. Release the Power button.
  3. Press the Power button to turn on the camera.
  4. When the camera turns on, you might be prompted to set the date and time.
NOTE:
When turning on the camera normally, press and immediately release the power button. If the power button is held for more than five seconds while turning on the camera, the camera might reset automatically while the lens is extending.
I found more information related to the AF Flashing that you are referring. Please open below link .
Link is :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00003782&cc=us&lc=en&dlc=en&product=90112&dlc=en&lang=en
Once if you open the link, please go through the information I guess that this should help you and will resolve the issue.
However, if the issue still persists then I recommend you to contact HP Support team on this issue. Because their expertise would help you better. For your convenience  I would like to provide a web link to contact HP Online Chat Technician.
Link is :
http://ipgweb.cce.hp.com/ipgna/caller/chat.asp?dd=camera&productName=HP+Photosmart+735+Digital+Camera&productCategory=12117&SCOID=82642&PSOID=90111&lang=en&cc=us
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I
Oct 28, 2007 | HP Photosmart 735 Digital Camera
HP Photosmart M307 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
