Question about Acer Aspire 3610 Notebook
Power inlet broken
How can i get it out to replace it
  • 837 Answers
AC inlet is broken on TX-SR875... How do I replace it?
A simple easy fix would be to hard wire it, solder a new cable in and secure it so it cannot be pulled out.
Feb 14, 2014 | Onkyo Audio Players & Recorders
The power is off but the dishwater fills with water
1) test the main switch for defective, to due is NOT possible electrical that the machine is working fill, with the power OFF.
2) test the water inlet valve for defective too.
God bless you
Sep 28, 2012 | Whirlpool 24 in. DU1055XTP Built-in...
Broken plastic water inlet connection.
I have the same problem. The design is bad with the weight of the hose and the lelength of the plastic inlet tube from the body creates a sheer force that causes it to break. I cannot find anything but a plastic inlet part. If someone would create a metal inlet connector they could make a lot of money. You need a lot of hose slack when moving your power washer or it will break off the inlet and the parts are abotu $20. Very poor design!!
May 08, 2012 | Honda Black Max 2600 PSI Pressure Washer
I have a ibm t60 laptop. The power cotd tests good. But the battery wont charge and the AC power light does not come on.
I see this same thing often, when people push in the power plug too hard, jostle the laptop around alot or even tried to force the wrong plug into the port---it sounds like you may have broken the solder on the mother board on the power inlet, There are 4, 6 or 8 solder spots on most power inlets, you may have broken one or more of them loose---take it to the shop if you are not handy with a screw driver and a soldering pen...
Feb 14, 2011 | IBM ThinkPad T60 Notebook
Maytag Atlantis Model Number MAV9501EWW has problem filling with cold water. I have switched the hoses and can fill with cold water through the hot water valve.
Hi.
Test and eventually replace the inlet valve.
The inlet valve is tested reading impedance, if it is broken, then it usually read infinity (circuit open). Reaing is done disconnecting valve and pointing multimeter probes at valve solenoid contacts (the cold ones in your case).
A definitive test on inlet valve is done reading volts while cycling and observing if valve is opening. For safety reasons is better if the user performs only tests that can be done with power off.
The switching contacts and inlets is also a test even if basic, I think that the valve is gone.
Here part:
Series 21 models: sub 22004333 (water inlet valve)
Series 12 models:VALVE-INLET
Valve is part nr.2 in diagram below. Click on the picture to enlarge.
If you repute this solution helpful, then please do not forget to accept.
Best regards.
Ginko.
Oct 01, 2010 | Maytag Atlantis MAV9501E Top Load Washer
When i put hose in port it will not turn on...all the other ports work except one
Open the door on the inlet port and look inside. You should see 2 small pins. These pins are spring loaded to make contact with the metal end of your hose when you plug it in. Two low voltage wires are screwed to the underside of these pins. The low voltage wires go all the way back to the low voltage switch/relay on your central vac power unit.
Sometimes one or both of these pins will just break so that they don't make contact with the end of your hose. If you see no pins or just one then you will have to replace the inlet cover.
If both pins are present; push down on them with your finger. If you feel resistance then your inlet is probably OK.
CAUTION: IF YOUR CENTRAL VAC INLETS HAVE A 110 VOLT CONNECTION, REMOVAL/REPLACEMENT OF YOUR INLET SHOULD ONLY BE DONE BY A QUALIFIED ELECTRICIAN.
Remove the two screws in the faceplate. Carefully slide the inlet cover out. Check the two screw on wiring connections. Make sure both wires are securely attached and that there are no breaks.
If neither of the above fixed your problem, you may have a broken or disconnected wire somewhere between this inlet and the low voltage witch at your power unit.
May 04, 2010 | Broan-NuTone CV353 Central Vacuum
Broken water inlet on Karcher 395 pressure washer
Had the same problem.Those hose inlet are very delicate.
I went to Home Depot,to the Garden Section in the hoses stand,and found a flexible connector for about $ 6.00 and I used it as a replacement for the broken hose inlet.
Good Luck!
Aug 16, 2008 | Dishwashers
Broken wire from power inlet socket
I finally managed to remove the cover and solder the broken wire. Works fine exept the keyboard, but that is a result of old soda spill. This computer has been used with external keyboard for some months. I cleaned the keyboard with luke warm water and placed it for dry for 36 hours, but there are still som keys that dont work and Fn seems to be constantly on.
May 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3610 Notebook Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
