Question about Sewing Machines
Juki LG 158 timing belt adjustment with take up arm position
3 Suggested Answers
madelinesalo
  • 59 Answers
SOURCE: Juki sweing machine timing problem
the timing of your sewing machine is, check your bobbin in right position, quit tightin the tension, and the timing for tiches is just always # 1.5
Posted on Mar 26, 2010
robert97527
  • 5 Answers
SOURCE: juki LG 158 feed dogs
Does the handwheel still turn..or is it frozen too? Call me at 541-474-9631 to walk you througha fix. Robert
Posted on Jul 09, 2011
I have a juki Ddl 8700 here it goes i was stitching a skirt then suddenly my needle got broken so i thought it just hit some of the pins attached in fabric so i put a new needle but then it just got...
1. The bobbin carrier is moving (needs adjustment on the left and right to keep it from moving.
2. (Most likely problem). The timing needs to be adjusted. Give it a try or get your repairman to do it. See 19. Needle To Hook Relationship.
Mar 17, 2015 | Juki DDL-8700
Timing on the Juki LU-1508H
HI THERE
please see attached for how to adjust timing between needle and hook.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Feb 18, 2015 | Juki Sewing Machines
Why is my juki machine 8700 not moving at 3000 speed
There are several manuals available, depending on detail and complexity:
JUKI DDL 8700 Manuals
Oct 16, 2014 | Juki Sewing Machines
How do we tighten the belt?
this might be it , though hit should be apparent to you if you look under it
JUKI DDL 8700 Instruction Manual Installing The Belt Adjusting The...
Jul 25, 2014 | Juki DDL-8700
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
E004:
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
E005:
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 04, 2014 | Juki DDL-8700
Timing belt repair
hi there
timing belt repair for witch model ????? many JUKI models has timing belt. need more information about your machine model then i can help you.
best regards
Ashraf
CAIRO - EGYPT
Sep 12, 2013 | Juki Sewing Machines
How to tighten belt on Juki ddl-5550
the adjustment is done by getting under the table and loosening the bolts on the big pully. Then hopefully it will drop some or might need to help it with a rubber hammer. Then retighten the bolts.
Jan 14, 2013 | Juki Sewing Machines
Juki LG 158 feed dogs wont move the feed cluth is lock in but the feed dog still wont move
Jun 26, 2011 | Sewing Machines
I have a Juki 654 Pearl - and the thread is looping on the underside. Tension adjustments don't seem to solve the problem.
Your hook might not be timed correctly. Sometimes a thread or fabric jam can dislodge the hook. When your needle is just starting to move upward from its lowest position, the eye of the needle should be just below the hook.
Mar 17, 2010 | Juki MO-654DE Mechanical Sewing Machine
Feb 25, 2009 | Juki DDL-8300
Sewing Machines Logo
104 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
