Question about Gaggenau AH 400-701 Kitchen Hood
Light socket replacement for Gaggenau AH400-701 Range hood
Where can I buy the stovetop burner gaskets?
  1. Gaggenau Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
Jul 11, 2015 | Gaggenau Cooktops
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
The light bulb keeps blowing out. Have the wires or socket gone bad and can that be replaced?
Remove the bulb and look closely inside the socket. If you see any evidence of burning or that it has been hot, replace the light socket. You can buy a replacement that will work at most any hardware store.
Feb 04, 2011 | Kenmore 51041 Kitchen Hood
Recently moved in and I have a Gaggenau exhaust/light hood that slides out over cooktop. I don't know model but controls are on right vertical side of unit. I don't have a manual and the light and exhast...
I have the same probelm. My control board is blown. You can see that easily if you open upm the case on top of unit in tehh cabinet in a smaller metal box. If it is blown like mine it will be very obvious.
Aug 05, 2009 | Gaggenau AH 900-761 Kitchen Hood
Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
Jan 27, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Gaggenau AH 250-760
I repair them in nyc all the time. unit will work for years after repairs. 1-888-nyc-1055
Jan 27, 2009 | Gaggenau AH 900-761 Kitchen Hood
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Gaggenau AH 400-701 Kitchen Hood Logo
Top Gaggenau Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Gaggenau Kitchen Range Expert? Answer questions, earn points and help others
