Question about Weslo Cadence G 5.9 Treadmill
A squeaking noise as I walk
I noticed after a day or so of use it squeaks as you walk. Do you have a clue as to what that would be.
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
My new Juki 2200 QVP is squeaking while I'm quilting with the walking foot. I have oiled all of the places indicated in the book. I've only got about 10 hours on this machine. Any suggestions?
Is it the walking foot that is squeaking? No one mentions that the moving metal parts need a touch of oil to keep the walking foot working. Just be sure to clean off any excess before using on your fabric.
Mar 30, 2017 | Juki Sewing Machines
How do I stop new tennis shoes from squeaking?
It could be the upper sliding on the sole. Taking a drop of extra virgin olive oil and putting at the flex point of the shoe should help.
Mar 09, 2015 | Nike Clothing Accessories
How *** i keep my boots from squeking hen i walk?
What is the problem? If the boots need dried out, do that. If the problem is caused by the upper squeaking at the flexpoint, a drop of extra virgin olive oil on the flex point will take care of that. If it is the layers of the sole squeaking when you walk, gluing them together can help.
Jan 29, 2014 | Clothing Accessories
What are the squeaking noise in my tires
If you have off road tyres with big nobbles the squeaking noise is the tread moving on the road . when the nobble hits the road it tends to slide forward and as the rubber compresses it then expands as the nobble leaves the road. Something like walking on lino with rubber soled shoes that squeak as you walk
Jan 14, 2014 | 2003 Ford Explorer Sport Trac
Squeaky noisy sneaker
it's very simple. just take out the insole from the sneaker, then put some talcum powder in the sneaker, then put the insole back. this will eliminate the squeaking.
the problem is that sweat gets between the insole and the inside surface. the friction between the two is the cause of the squeaking.
May 09, 2013 | Nike Air Monarch III Shoes
Nordictrak T5.7 treadmill squeaks while walking
please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Jan 08, 2013 | Exercise & Fitness
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Weslo Cadence G 5.9 Treadmill Logo
204 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
