Question about Sharp LC-32SB24U 32 in. LCD TV
TWO CHANNELS (CABLE) SOUND NOT WORKING
Could u tell me why all but 2 channels on our new LC32SB24U tv work fine except for cable channels 57 & 58 which are the CNN channels? All others, in home, work fine on these channels.
  • 33 Answers
Try turning off the tv and unplugging it for one minute, if that doesnt resolve the issue, look into gettnig a converter box, or a signal booster to help. The tuner's in those SB model sharp televisions are not worth a penny and they need a very strong signal to be able to interpret all of your stations without problems. good luck 2 u
Posted on Feb 19, 2009
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
No sound on certain channels.
All the apartments complex have it than it not ur tv.It the cable company signal problem.Tell the maneger call talk to the company check the wiring.
Jan 13, 2010 | Toshiba 19LV610U LCD TV
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Nov 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Any idea why on my new sharp 32" lcd tv, all cable channels except 57 & 58 (CNN) work fine, but on these channels the sound goes off and on, like there is a short in the sound. all other tvs and cable work...
If you do not have problems with picture and sound on all the other working channels, then the problem you are having with 57 & 58 cannot be a short. The problem you are having is that those channels will not tune in properly through your tuner and this is why you get intermittent sound when they are trying to tune in. The sound tunes in easier than the picture. You said that you have programmed the channels again and I am assuming you are talking about the autoprogramming mode. Try to program those channels individually by deleting them and then readding them. If you cannot do that then you need to take the tv back since it is new or have warranty service look at your tuner and setup your tuner by making adjustments to it directly. Good luck and God bless.
Jan 22, 2009 | Televison & Video
JVC LT 43E488 LCD HD TV cable box doesn't get local channels
boomergal, do you have satelite cable or directv or dish?
Dec 12, 2008 | JVC AV-36D303 36" TV
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
TV gets all channels, except 2-6
In most cases when you set your menu ("tuner section") to cable, the tv will pick up all channels, but if you set it to "off air" or "antenna" (or whatever the other choice is labeled), then the tv will only go up to about channel 50 or 60. Are you using cable, dish, or an antenna on top of your house. If using cable or dish, then go into the menu on your tv and set the tuner to "cable". I am pretty certain that your tuner is NOT currently set on "cable" and that also there are no local "off air" channels in your area on 2 thru 6, therefore, you see snow on these channels. I have repaired hundreds of tv's and I feel very strongly that your problem is in your menu.
Keever
Mar 04, 2008 | RCA F31317 31" TV
No picture channel 2-3-4-5-6-7
bad tuner or gemstar module
Dec 08, 2006 | RCA F32649 32" TV
Sharp LC-32SB24U 32 in. LCD TV Logo
151 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
