Question about Kodak EasyShare C330 Digital Camera
Camera won't turn on
My camera won't turn on. I know it is not the batteries because they are brand new and ive tried different kinds. And usually if the batteries are bad the light thingy will flash red. My camera may have been dropped but i am not sure. Please help
    Genius:
  • 2,985 Answers
What sort of batteries are you using ? Alkaline do not have the oomph to run a camera They need to be Ni-Cad or Ni-Mah Check out the Tech Support Web Site at Kodak
Posted on Jul 05, 2007
SOURCE:
Polaroid camera will not turn on
If it is a new camera, it is strange it switches off so quick. On the other hand, alkaline batteries are not the best choice.
You better use NiMH rechargeable, because they can keep up a high voltage longer. Always us batteries from the same batch. Never mix batteries from different sort, like NiMH and alkaline.
NEVER Never use manganese (Zinc-Carbon) batteries in your camera. They should be in a flash light. They don't have enough capacity and can leak easy.
Always check the contacts on the batteries are clean and shiny. (Also the contacts in the camera. You can clean contacts with a dry cloth or cotton swabs.
If it is a brand new camera, and it won't work as expected, bring it back to the shop.
Oct 07, 2014 | Cameras
Cant take more than 2 pictures because it says the batteries are too low, while new batteries are in. What can i do?
Just a hunch - your camera's in-built capacitor is malfunctioning. You need to send your camera to service.
Aug 30, 2014 | GE A1250-BK 12MP Digital Camera with 5X...
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
My finepix s1000fd will not hold battery charge. Cleaned the battery connects. New duracel batteries are discharged in an hour of being in camera on off. I tried new rechargable batteries and they will not...
Try using a different type of battery (not meaning *brand). Many newer digital cameras will only operate properly with high alkaline batteries vs other types. I was having the same problem with my Sony cyber-shot and found out that I had been using the wrong KIND of batteries all along. Hope this post was helpful to you.
Jan 27, 2010 | Fuji FinePix S1000FD Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Kodak easy share c875
When you say you've tried every different kind of battery, did that include Lithium batts?
Lithiums are the only battery that ALL Kodak cameras seem to be happy to run on.
They have huge problems with alkaline batts, even brand new ones.
Hope this helps.
Dec 29, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
69 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
