Question about PopCap Games Bejeweled 3
Unable to extract game executable - PopCap Games Bejeweled 3
Extract game executable
Extract it It works.........
Apr 20, 2013 | PopCap Games Plants Vs. Zombies
Philips Photo Frame Failed to load executable file
Download the last Firmware-File from Philips and extract it. In the extracted folder is a file called execute.bin. This file must be moved over the Micro-USB-cable to the internal root folder. After a restart the photo frame should be automatically install the last firmware.
Dec 02, 2012 | Philips PhotoFrame -10 Digital Picture...
I already cracked the incredible hulk game but it says that i need to place the game disc on a drive
The procedure if you have the crack is to copy the crack file into the director folder...and usually it works ..
so ..if you have the crack ..you see that it is just a executable file icon ..extract it if it is zipped..and copy that file in the folder of the game ..It will ask you if you want to replace the executable file ..and confirm ..after that strt the game from it ..or make another short cut for it ..on the desktop ..to get to the director folder ..go to ..C drive /program files..and open the folder with the game .
You may try to look for other fix on the net ..there are threads with discussions about it ..and most of them have downloads for this kinda ..operation ..remember the crack is not something you need to install for games..but just another executable to full it and think it has a disk ..
Another thing you may try is to install daemon tool ..and play the game with the image of the game mounted into a drive ..This way the computer will not make the difference in having a disk or this image ..It will only see the files in a drive .
Dec 28, 2011 | Sega The Incredible Hulk: Ultimate...
I have downloaded BLC 99 from RapidShahre. I Installed it in my PC in Win-XP operating-system. & then, I extracted the Executable files from the source folder "Vision", then extracted them...
Make sure the size of game that u have downloaded is about 457mb.
After that u have to install a virtual drive(Im using Power ISO virtual driver manager).
Now install both(i.e game and virtual drive). Mount the the image(blc99) to drive(by going in power iso software installed options.)
For further more, check this blog, it helped me a lot.
http://blog.vibsworld.com/gaming/my-brian-lara-cricket-99-se-2008-re-release/#comment-617
M.Robeel
May 24, 2011 | Computers & Internet
How can i extract [isoHunt] All Pokémon Games
The torrent that you have downloaded is not the actual game, it is in fact a link to multiple different computers. This torrent file will tell your computer where to look to download the actual game.
To launch the Torrent in U-Torrent, just double click on it and this will locate the peers or the source of the actual file.
Then once the game or file is downloaded you should right click on it from U-Torrent and click on "Open File Location" Or "Execute File" to run the installer and this will lead you to the installation process.
The installation process will then guide you through each step.
Thank you for using FixYa! Have a great day and please remember to rate this solution.
Best regards,
BearWeb
Jan 10, 2011 | Systran Home Translator 6.0 World
How do you active a patch for a game once you download it? It is an unofficial patch
This depends on the game and who made the patch.
MOST patches have what is called a self extracting installation file.
Assuming this is a windows machine.
It should have an .EXE extension. Double clicking this will cause the file to execute and install. Be careful however. Unofficial patch Screams VIRUS!!! Also keep in mind running patches will cause anyone with a different version number to be unable to connect with you in a multi-player game.
Use caution and certain of who and where this patch came from.
Oct 03, 2009 | Jade Empire Special Edition for PC
Counter Strike Hack error
try hacks like HOOK BADBOY open ur counter stirke then double click the hack
Jan 04, 2009 | 321studios Games X Copy (900242) for PC
Grand Theft Auto SanAndreas
Grand Theft Auto: San Andreas also uses Securom copy protection software.
Please read the below mentioned. The same solution which I had posted for the game Juiced.
The solution is the same for all games using Securom copy protection software.
Securom is a copy protection software that sometimes conflicts with any background applications,multiple disc drives, virtual drives, USB storage devices (Pen drivesand USB Hard drives).
This however can be solved once you submit a analysis file to the Securom Support.
To extract the Analysis file you can follow the below mentioned.
Open Game folder
Locate "GTA_SA.EXE" file and then right-click on it context menu will appear
Select "Launch Analysis" within that menu
After the selection a disclaimer window will appear on your screen, to proceed, click the "YES" button
This 'analysis' will now generate an 'AnalysisLog.sr0' file within the root directory your C: drive.
Go to your "C" drive to locate the "AnalysisLog.sr0" file and zip the file compression utility programs such as WinZip, Winace or Pkzip
-Submit the Zip file to: support@securom.com for evaluation along with "Grand Theft Auto: San Andreas " in subject line.
Securom support will then analyze the file for conflicts and send you a new executable file. Once you have the new file, extract and paste the executable file in the root directory of the game.
Oct 22, 2008 | Computers & Internet
Juiced
It is a Securom conflict that you face. Securom is a copy protection software that sometimes conflicts with any background applications, multiple disc drives, virtual drives, USB storage devices (Pen drives and USB Hard drives).
Open Game folder
Locate "juiced.exe" file and then right-click on it context menu will appear
This 'analysis' will now generate an 'AnalysisLog.sr0' file within the root directory your C:\ drive.
-Submit the Zip file to: support@securom.com for evaluation along with "Juiced" in subject line.
Securom support will then analyize the file for conflicts and send you a new executable file. Once you have the new file, extract and paste the executable file in the root directory of the game.
Oct 18, 2008 | Video Game Consoles & Games
PopCap Games Bejeweled 3 Logo
35 people viewed this question
Top PopCap Games Video Game Consoles & Games Experts
EnergeeUK
Level 1 Expert
ray gallant
Are you a PopCap Games Video Game Console and Game Expert? Answer questions, earn points and help others
