Question about Dell Latitude D600 Notebook
S-video out isn't working
When plugged into monitor doesn't show.
  • barraganarq Mar 19, 2009
    i have the same problem i think. I connected a projector to my laptop, went to properties, and then display properties, but the external display or monitor 2 never shows up. I tried rebooting, and nothing. What could be the solution?
  • 51 Answers
Once you connect the S-Video to a monitor, go into your display properties, usually right click on the desktop and select properties and then select display properties. under the monitor tab right click on the Monitor #2 and select attached. This should now show up on your external monitor.
Posted on Jan 25, 2009
Aspire AX1200-U1510A starts but monitor doesn't show anything. Monitor works with an odl Dell.
If an old Dell monitor works with your computer then that monitor has something wrong with it.
Try to plug in the monitor to a wall outlet but do not plug it to your computer. If it still doesn't show anything, then you should replace it. You can contact the manufacturer of the monitor. You might have a warranty for it. They might fix it or replace it with a new one.
I hope this helps.
Carlo
Nov 20, 2012 | Acer Aspire X1200U1510A PC Desktop
HP w2207 no vga input signal, no dvi input signal monitor goes to sleep
There is no signal coming from your PC.
excuse some of the solutions as sounding dumb, but we have to explore all possibilities.
Check the power cable going into the computer
Check the power input disconnect switch on the back of the power supply and make sure it is on
If the pc is plugged into a power bar, make sure it is turned on and the breaker isn't tripped
press power on the PC and make sure the lights are coming on.
now for the solutions that may actually help.
disconnect the power from the PC
if the video is on a card, remove and re-seat the video card
hook the power back up, connect the monitor and try again.
the CMOS on the computer may need to be reset.
I hate totally clearing the CMOS, so what I usually do is remove 1 stick of ram and power up. If the system is alive again, power down, put the RAM back in and power back up.
If that doesn't work, turn the system off, put the CMOS jumper to the CLEAR position for 15 seconds, put it back to the Normal position and then power back up.
Basically, if the monitor works on your friends system but not on yours, the the problem is your system, not the monitor (assuming it isn't working fine til it gets into windows...if that's the problem, you have a driver or configuration problem)
Jun 10, 2012 | HP Computers & Internet
Laptop turns on but screen doesn't show
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 07, 2012 | Acer Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
I am attempting to connect my HP pavilion dv9000 to a HP 2310e monitor, but it doesn't recognize the monitor via the HDMI cable
You must make sure it's configured correctly: make sure the monitor is up and running (not in Sleep) , that the HDMI cable is firmly plugged in (use a new one to be sure), then right click on the desktop, click NVidia Control Panel, under Select a Task expand Display and click Run multiple display wizard . If the monitor isn't picked up then go to Set up multiple displays options and see if the monitor appears in the second setting (Select the displays...) - if it doesn't then click the MY Monitor is not shown in the list option and follow the procedure to force its detection.
If even that fails then the video driver is corrupted, you will have to uninstall it, download the latest one and reinstall it.
Use this one
http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html
Aug 12, 2011 | Computers & Internet
TFT185W80PS monitor is not working
Check if your monitor power led indicator is on if it is, try to check the cables of your monitor if it is properly plugged to your CPU if it isn't plugged it properly if the problem still doesn't solve try to open your cpu and and uninstall your video card if you have a separate one and clean it with a pencil eraser then install it again and try it if it will work. But if your video card is built in, there is a problem with your video card or maybe your monitor try to contact a reliable computer technician..Hope it will help you.
Jul 02, 2011 | AOC widescreen 931SWL LCD TFT 19" Monitor
As soon as it come on it shutdown and lcd is dark but you still can see in dark lcd
It doesn't sound like the system is shutting down. It sounds more like the LCD display back-light isn't working. Try connecting an external monitor to you system and booting it up. You may find that the external monitor has video. You may also toggle through the three state video selections. Hold down Fn and tap F7. this should take you through all three steps. Good luck.
If this was helpful Please rate the solution high. thanks.
Apr 20, 2011 | Acer Aspire 5100 Notebook
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Philips 170c Lcd star`s but it didn`t remains on
Make sure that the video card (if you have one) is firmly inserted into its slot.
Make sure that the connector from the monitor is firmly plugged into the CORRECT video slot on your back panel... Your video card may support more than one monitor and you may have it in the non default port.
Also make sure that the video driver is up to date or even installed.
As much as I hate to say it, there is also the possibility that the monitor is bad.
Feb 21, 2009 | Computers & Internet
Dell Latitude D600 Notebook Logo
347 people viewed this question
Alun Cox
