Question about GE 24 in. GSD2000Z Built-in Dishwasher
Dishwasher not getting water
My water supply is fine to the GE dishwasher (model # GSD2000G00WW), but no water is getting into the machine
    Novelist:
  • 161 Answers
Check the solenoid on the water valve.
The water supply connects to the dishwasher water valve, two wires are connected to the solenoid. An OHM meter will tell if this is good. If good, set meter to volts and see if 110 is getting to the solenoid, you will have to turn the timer to the point where water should be coming in.
Posted on Jan 22, 2009
GE models in the Medle East (problem with heater and salt)
Cold is probably more efficient unless you have solar heating or your how water cylinder is right next to the washer with minimum amount of piping otherwise by the time the hot water reaches the machine it will have enough in it anyway :p I dont have much experience with water hardness issues as water in my region is quite soft but you can get tablets containing? softener as well as detergent... yes?
Feb 25, 2010 | GE Dishwashers
About GE Dishwasher
well all I can say is, I have ONLY cold water connected to mine, A Parmco, & it works fine? I have many friends, using the same method. It will however take longer to wash, and as you say must heat the water up. But so what? I wonder if you aren't being told "Porkies"? Also "Connected" and "Being used" are two different things, right?
Feb 24, 2010 | Dishwashers
Water does not pump into dishwasher from line, tho
the start buttom lights geen for 7 times , may be from the lack of water , but the water supply was solved & the dishwasher didnt start again !!!
Feb 01, 2010 | GE Dishwashers
WHERE DO i FIND A DIAGRAM OF HOW TO TAKE APART MY GE DISHWASHER GSD200 G00WW?
Three Schematics for escutchion and door, body parts, & pump and mechenisms are available at sears parts direct for most models. your model numbers diagrams are at
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GSD2000G00WW
Nov 13, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE Dishwasher gsd2200g00ww water supply valve
dishwasher g e model GSD2200Z00AD WON'T DRAIN WATER
Jul 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Hello! My GE Dishwasher (Model # GSD2000G00WW) will not fill. The water supply is flowing properly after cleaning out some lime and mineral deposits, but no water is going into the machine. If the water...
I need to know is the water not going in the machine at all in other words when you switch on the machine with the tap open can you hear the water flowing,if you can here the water flowing check the hight of you drain hose if it is too low down you will find that you end up with a syphoning effect as the water goes in the machine it gravity feeds out the drain pipe if the drain pipe is low lift it up (about half way of the machine is a general indicater) if you cannot here water flow and the tap is open and machine on it could be your inlet solonoid,it may also be your pressure switch if the machine was tlted it may get water in the pressure tube in wich case you will need to locate the pressure tube and blow it clear if there is water in the pressure tube the pressure switch will think the machine is full,worst case is the (timer or pc board) wich ever your machine has is fualty but this is seldom the case
Jan 22, 2009 | Dishwashers
Ge top load washer WSERE526FOWW
Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Sep 11, 2008 | GE Washing Machines
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 24 in. GSD2000Z Built-in Dishwasher Logo
696 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
