Question about Kenmore Dryers
How many cubit feet in dryer kenmore model 76433800 stock 64338
  • 3 Answers
SOURCE: my kenmore dryer turns on
check your sensor
Posted on Jan 05, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Posted on Jun 14, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer not heating on any setting.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer if you are then:
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Nov 13, 2009
heatman101
  • 43501 Answers
SOURCE: What is the cubit feet for Sears refrigerator
This tip will show you how to measure your refrigerator and then figure out the cubic feet on your own...
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
heatman101
Posted on Apr 17, 2010
mkh5094
  • 145 Answers
SOURCE: how do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Posted on Apr 27, 2010
How many cubic feet is my kenmore dryer model 110.79812990
The capacity of a dryer is measured by its drum volume in cubic feet. Measure the depth of the dryer from the back to the door opening. Measure the diameter of the dryer. Divide the diameter by two to find the radius. Calculate the size of the dryer by squaring the radius and multiplying by the depth.
Jan 13, 2018 | Kenmore Refrigerators
WHAT IS THE CUBIC FT CAPACITY OF MY 361RFD SIDE BY SIDE
How old is it? Because I have 2 answers either 29.8 cubit feet or 28.4 cubit feet.
Jul 04, 2017 | Refrigerators
How many cubic ft is my GE refrigerator model# gts22ibmbrww and serial# hd311205
On GE Refrigerators they place the cubit feet numbers into the model number. Yours is 22 cubit feet
APPLIANCE 911
Feb 01, 2016 | GE Refrigerators
Model #gth18cbc2rcc
That is 18 cubit feet, Thanks Sea Breeze
Aug 06, 2012 | GE Refrigerators
What is the cubit feet of this model please?
Go to sears.com they should have the specifications there for you.
Feb 10, 2011 | Kenmore 63942 Dryer
How much is one cubit, to inches?
1 cubit [Roman] is 17.4803149606 inches
If you are referring to cubic feet to inches then you need cannot when cubic feet is a volume measurement and inches is a length measurement.
Jul 17, 2010 | Acme Automotive ACMA680CS Typhoon High...
heatman101
Apr 17, 2010 | Kenmore Refrigerators
How many cubic feet is the Kenmoore model#110
MODLE 110 IS YEST A CODE FOR KENMORE TO LET THEM NOW IT WAS MADE BY WHIRLPOOL AND MOST OF THEM THEY ARE 2.5QF
Jan 24, 2009 | Kenmore 63942 Dryer
Dryers Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
