Question about Refrigerators
Gsh25jftaww stop working not frizing
Stop working not freezing
  • 17,130 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Posted on Jan 12, 2013
Where is te freezer temperaure control on my ge side by side m/n#gsh25jftaww ?
The temp controls are either analog rotating knobs on the interior or via a digital panel on the freezer door along with the ice and water control buttons. Here is a link to the appropriate page in the manual. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-3.pdf
Aug 18, 2014 | Refrigerators
Astak camera manual
This fridge doesn't have a mechanical defrost timer.
The main control board at the back is responsible for the defrost
cycle.
Apr 18, 2014 | GE Refrigerators
Gsh25jftaww
Look at the freezer back wall. Do you see any ice buildup?
Oct 21, 2012 | GE Refrigerators
Jfi2089aep frizzing fresh food section
can you please explain better?
Aug 28, 2012 | Refrigerators
My kenmore refrigerator is frizing everything what can I do?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Refrigerators
Display at my H461 A seiko is frized. how I can reset or set it to factory setings???
Mine even worse: battery was too big so now display half black.
How can it be fixed?
Jul 25, 2010 | Seiko QHR016SLH Clock Radio
How do I obtain a manual for a GE refrig - model GSH25JFTAWW
Well you can please follow the below link to get your manual -
http://www.devicemanuals.com/guide/Refrigerator/GE/GE-GSH25JFTAWW-Side-by-Side-Refrigerator-Owner's-Manual-==TWprME1UWXk=.html
(Just copy and past the above link in your web browser, and follow the steps to download the manual)
Good Luck!!
Thanks
Mar 01, 2010 | GE GSS25JFM Side by Side Refrigerator
Won't go to menu even though I hold it in for 3 seconds
well this is what you do when that happin. when it frize up like that trun it ff then trun it back on go to setting and change it around then go back to rec and when you stop it hit the return button and go back to the main menu. thats all to it hope i help you out later
Jan 21, 2009 | Audio Players & Recorders
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
