Sharp AR-336 copier was moved, now it will not power on
We moved the copier from one office and then back to the original office. The copier is plugged into a active outlet, but nothing happens when the power switch is pushed.
Is there something internal that needs to be done?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
No, its possible you blew an internal fuse in the machine. only one power switch.
Posted on Feb 25, 2009
How to fix a H5-02 code on a Sharp AR-336
input C + interrupt + 0 + interrupt +start +14 +start
Dec 05, 2013 | Sharp AR-C160 Color Copier
Sharp ar 336 copier
remove the fuser unit and clean the thremister, but 1st turn machine off, upon reinstall of fuser enter service mode p*c* and choose 014 to reset the code, if that doesn't work you may need a new fuser
Nov 09, 2013 | Office Equipment & Supplies
Sharp copier ar-336 error h3-00
H3 00 Fusing section high temperature trouble
Detail: The fusing temperature exceeds 242°C.
(An input voltage of 0.27V or above is
detected.)
Cause: thermistor trouble
Control PWB trouble
Fusing section connector disconnection
AC power trouble
Check and remedy: Use DIAG (SIM5-2) to check the heater lamp
Blinking operation.
If the heater lamp blinks normally:
Check the thermistor and its harness.
Check the thermistor input circuit in the
control PWB.
If the heater lamp keep lighting:
Check the AC PWB and the lamp control
circuit in the control PWB.
Use DIAG (SIM14) to cancel the trouble
Feb 10, 2011 | Sharp AR-M237 Copier
Salut je cherche solution par rapport à un code Code H3-01 sharp AR 336
The problem is in your fuser section. You may have a bad thirmistor or heater lamp or the main pcb. Good Luck...
Jan 22, 2010 | Sharp AR-M237 Copier
HAVE A SHARP AR-336 WITH A CODE H3-00 HOW DO I FIX THIS
You can try this it works for older Sharp models.
  1. Press # key
  2. Press * key
  3. Press C key
  4. Press * key
  5. your display will stop flashing H 3, if not re-enter the keys again, some machines are temparmental, when it goes blank
  6. enter 14
  7. press the start key then turn it off and back on, if it comes back with an h code there is a problem with the heat section and will need a service call and probably parts.
  8. good luck
Apr 21, 2009 | Sharp AR-M237 Copier
I have a Sharp AR-336 that's showing me F1-00 error code. What is this and how do I fix it?
F1-00 is a communication error between the copier and the finisher. It could be a loose connection (wire that connects finisher to copier) or it could be worse like a failed board. It could be the finisher board or the PCU board on the copier.
Make sure the finisher cord is firmly connected to the copier.
Make sure the copier is not plugged into the same wall outlet as another piece of equipment that might be drawing excessive power. do not plug into a cheap surge protector with other items.
If problem persists call a tech.
Hope this helps
Apr 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
Ar 336 sharp copying machine code F1-05 please help
If you have a finisher on that unit ,that code is upper limit switch problem. Check to make sure your upper tray is in the right position. Otherwise your either your tab is broken or your led is popped.
Jan 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Problem with my sharp AR 336 code F1-05
Hello, this is a sorter bin home sensor fault. First shut down machine and disconnect all power. You will need to remove the front and rear covers of the sorter, then you will have to manually turn the spindles/ cams as to more the actuator off of the home switch. Once you have released the home switch/ sensor, give a little extra space -- apply the power and watch. The cams should move the bins to switch/ sensor and reposition. Once you have made sure that it is working, shut down the power and disconnect power. Install covers back onto sorter and apply the power. If, when the power is applied before you installed cover, if the cams keep driving and do not stop and code comes back, that bin home switch will need to be replaced.
Dec 31, 2008 | Minolta Di3510f Bizhub Copier
52 people viewed this question
jasbo
jasbo
