Question about Welding Tools
Sealey supermig 220 auxiliary transformer fuse replacement
2 Suggested Answers
SOURCE: i need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Posted on Apr 23, 2009
Sealey supermig 180/1 wont feed the wire when trigger is press help
Can you hear the motor? If you can, tighten the tension on the wheel. If the motor is not runnung, check the trigger switch to see if it's working. A wire in the handle may have broken.
Dec 30, 2013 | Welding Tools
Hi, I stupidly turned on my brand new Francis X7 machine without using a transformer (I bought it from the US, used it in Malaysia), and of course, something blew, and it now doesn't work at all. Any...
The machine is made to work with 120 volts and you have plugged this on a 220 volt mains circuit thereby blowing up the fuse, or the power circuit, possible heater and the main controller unit board.
A step down transformer was needed to work this unit safely . Now unless the unit is opened the damage cannot be confirmed but if you are lucky the fuse would ahve blown and saved the rest. if so test it with a new fuse using a 220 to 120 volt convertor.( transformer with good rating)
Jul 05, 2011 | Microwave Ovens
Hi i have a sealey space warmer it will not power up and i have checked the 2 fuse's and they are ok can you help please thanks
Dear discophil,
If you contact the technical hotline for Jack Sealey Ltd on 01284 757500 they should be able to solve your problem for you.
Regards,
Jack Sealey Ltd
Nov 08, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Change from 110 to 220 volts transformer
It sounds like the replacement 220 volt transformer is putting out too much power, as replacing a 110 volt transformer with a 220 volt one should have no effect on other components, as the output voltage and amperage should be the same as the original one.
Apr 05, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
I'm in Iraq and I brought my ultratone k450fx with me to play my korg synth and being exciting to finally be able to play I plugged it in without using a transformer and blew a fuse, what size do I need to...
In Iraq I assume the voltage is 220-250.  The fuse you'll need is a 220-240V 1.25A H 250 V.  You can actually use this model without a transformer/converter if you have the voltage selector set to the non-North America setting.
Play well!
May 17, 2009 | Behringer Audio Players & Recorders
I need a power transformer for roland sde -3000
Dec 11, 2008 | Music
I have a 5ton package unit electric/natural gas. unit is 2yrs old. There is 220 v0lts to the unit. unit will not come on. there was some voltage surge during bad weather at the time unit went down. the...
This can only be 1--of 2 things, (the easy fix first, transformer or curcuit board is bad) .If you have 220 volts then check for power going into the transformer, (220 vt) and then power going out, (24-28vt) (90% of the time, its the transformer, 10% of the time, its the cuircuit board.! , i
Sep 13, 2008 | Goodman Heating & Cooling
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
