Question about Simplex 4098-9755 Duct Smoke Detector Kit
Simplex 4098-9755 Duct Smoke Detector resetting
2 Suggested Answers
  • 3 Answers
SOURCE: 4098-9613
http://www.simplexgrinnellstore.com/products/fire_detection_alarm_systems/detector_sensor_heads
Posted on May 26, 2012
I have 6 smoke detectors & two CO2 detectors hardwired in. The smoke detector in the kitchen went off and now all the detectors will not stop alarming. How do I reset?
First of all, you really should not have a smoke detector in the kitchen as it will be far too prone to false alarms, especially since most household smoke alarms are ionization type, which respond to the presence of gases caused by combustion. A proper system as recommended by NFPA will have one detector in each bedroom, one in each bedroom hallway, and recommended one per floor thereafter, with placement being near exit points to help guide you to the exit during an actual fire (by sound, since it's difficult to see through smoke). I would be inclined to remove that device or try to find a heat detector replacement, such as Kidde Model # HD135F. For now I would vacuum out the device or try a can of compressed air to blow it out, but I would not leave that device long term.
Sep 13, 2015 | Home
My 521NCSXT smoke sector beeps periodically. What is required to repair?
When a smoke detector beeps periodically it is telling you that it needs a new battery. They require the newest 'alkaline' 9 volt battery that you can get. If it is not alkaline you will get the beeps. once the battery is replaced do a hard reset. (pressing the button for 10 or more seconds)
Sep 29, 2013 | GE 521NCSXT - Photoelectric 2-Wire Smoke...
How do you clean the detector head on a Siemens AD@-HXR Duct mounted smoke detector?
You can't It operates off of nuclear radiation and has an expiry date just like milk. every 4 or 5 years recycle them and get another one
Aug 01, 2013 | Siemens Ad2-xhr Duct Housing W/relay Smoke...
Simplex 4259-24 smoke detector
sensitivity: 1.5%FT (0.2 DB MTR)
Jul 31, 2012 | Home Security
May 26, 2012 | Simplex 20989442 Fire Alarm Heat Detector
How do you test a Honeywell smoke detector
Home Depot or Lowes sells "smoke in a can". Use it sparingly to test your smoke detector.
Apr 10, 2012 | Honeywell 5808w3 Photoelect. Smoke Heat...
Have an AD2-P siemens smoke duct detector that is rated at operating temps from 32 deg to 100 deg. Now is this the range temperatue that the inside of duct can be before alarming? The application that we...
Operating temp are the control limitation. U Have to keep air flow whiten those boundaries. As to the humidity, no problems as long as you do not go above 85% RH and make sure no condensation occurs. Regards Guy
Aug 12, 2011 | Heating & Cooling
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Went to a family dollar with a roof top unit and at the time could only check right above the drop ceiling, where there was a return and supply flex and a piece of square duct going through the roof and a...
sounds like a smoke detector to me. usually they just break the red or the green through a relay, if it smells smoke. could be dust burning off the heat strips first use, or you could get on the roof and find burned wires or motor. lots of old wires burning up with heat strips kicking in this time of year. i usually have em turn off alarm so fire dept wont come and turn to max heat and burn off the strips , measure amps, check wires, and all relays etc. you may have to bypass smoke detector till done. then return to correct "as found" wiring and reset alarms. hopefully no call backs. good luck.
Nov 21, 2008 | Heating & Cooling
Simplex 4098-9755  Duct Smoke Detector  Kit Logo
52 people viewed this question
Top Simplex Home Experts
Donni Steen
Tom Chichester
Are you a Simplex Home Expert? Answer questions, earn points and help others
