Question about Dell E173FP 17" LCD Flat Panel Monitor
"Waves" generating from the right of the screen.
I replaced my power supply today, due to damage from a storm. The original was 300w, but I couldn't find one in my city, so I bought the closes I could find, which was a 350w. I installed the power supply, and turned on the PC and my monitor has these sort of "waves" on the right side of the scree, that occasionally come across the whole screen. There's no color change, the picture's just distorted along these lines. They don't really interfere with what I see, it's just annoying, and obviously a problem. When I reinstalled my old power supply just for a test, it went back to working fine like it had before..what could have caused this?
  • 432 Answers
It's power distortion. If you move the monitor away from the pc, the waves will stop. It's magnetic distortion causing this interference. Your monitor is fine.
Posted on Jul 05, 2007
  • 3 Answers
My theory to sp3ct3r problem...That also happened to my supply...what I figured the power surge put the inverter in the suplly on "over load" and the supply shut down as the capacitors are "over charged". Once this charge bleeded with time, then the power supply was in essence"reset" and all is fine. However, one might think damage had to some level!!!!!
As to the higher wattage rating that is runs cooler and also you can add more peripherals down the road demanding more power without overloading the supply.
Posted on Jan 06, 2008
    Problem Solver:
  • 15 Answers
Could you try to change the refresh rate of the monitor. Just right click on the desktop click on the settings tab on the window that appears then click on the advanced button at the bottom and another windows appears then click on the monitor tab try changing the refresh rate at the drop down menu untill the monitor stop the waves
No power could it be fuse
yes but let me caution you , microwaves use a high voltage power supply x10 your power inside your home (to generate cooking waves) on most models the "fuse" is located inside the case right next to this high voltage supply , and even with plug pulled out it retains its power for long time
if your not familiar with these id recommend using a professional to repair this pure safety in mind
Oct 29, 2015 | Microwave Ovens
I dropped my Blackberry Storm today. Everything looks normal, as far as the menus, but when I go to select anything, it doesn't recognize where I am touching or it selects something different. I have...
The problem you are describing occurs mostly when the digitizer, which is the device that actually responds to and identifies touches and gestures on touch-screen devices is damaged. Depending on the manufacturer (or phone to phone) the digitizer can be a small, thin layer that needs replacement; while other times, it can only be replaced when replaced the LCD screen due to the fusing process that most devices undergo from factory.
In the case of the 9530, the former appears to be the case. Luckily, there are several shops online (like, for example) that carry these replacement parts for about $15-30 plus shipping & handling. Most of these come as a kit, which include all the necessary parts & instructions to swap out the damaged part yourself.
A simple Google search here will perform a search for "storm 9530 digitizer oem" and will layout the results from various companies that cater to replacement parts for high-end cell phones.
Please note, while some companies will sell you very low price parts, it is recommended to go with an "OEM" part. OEM stands for Original Equipment Manufacturer and the difference between OEM and non-OEM parts is two-fold.
Even though they may look identical, OEM parts are actually crafted to adhere to the same standards as the original part that came with your phone. Meaning all of the quality assurance, stress testing and compatibility is guaranteed when using OEM parts. Non-OEM parts may work the same and will most likely be cheaper, but beware buyer as these parts are usually inferior in quality, cheaply made and can sometimes cause compatibility problems with other parts of your phone, in this case, the screen may be affected.
Jul 27, 2011 | RIM BlackBerry Storm 9530 Smartphone
Vizio plasma tv will not turn on by button or remote, cable box is lit. We had a loss of power last night due to a storm. What do we do to check it.
hi usually the cause of won't power on problem due to the storm is the current fluctuation which the tendency is power supply failure. now since totally dead set what you need is to open the tv unit then look for the power supply where the power cord is connected. check obvious defective component part like blown fuse and burnt part like resistor and capacitor. just replaced with the same value and ratings to avoid damage from others component.if their is no problem with the power supply the output voltages are good the main board get damaged. good luck thanks for consulting the fixya.
Jul 14, 2011 | Televison & Video
Lightning storm & power went out for about two seconds. PC plugged into surge protector but would not go back on. Found that surge protector blew and was no good. Got another and plugged all back in...
Your reasoning about the switch mode power supply being damaged is probably right.
Bear in mind that this power supply may not be the only thing that may be damaged in your computer.
You won't know for sure until you borrow a power supply and install it into your computer to see if it will work again.
Jun 18, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
We just lost power due to storm and my xbox 360 was plugged in with the generator running and now we have power but my xbox 360 will not turn on. I havnt the slightest clue what to do.
Leave it off for a few minutes then try to reboot it. If it continues to stay dead after your original power source comes back on, you may want to take it to a technician to have it looked at. It's very possible that the storm could have blown the battery, but lets not jump to conclusions so soon!
Jun 06, 2011 | Video Game Consoles & Games
Following electrical storm. No display and oven control erratic
Possible high voltage could have damaged the power supply or the main program control board. So you can remove the control panel after disconnecting the power cord. If you notice any capacitor leak replace and test. If not the processor/ controller IC must be checked for failure to drive the display and run the program due to a static damage to the chip.
Jan 06, 2011 | Ovens
R38 Open Circuit what is value
What do you mean?
Its a low power PSU to use at modern board, 500W should be the minimum requirement for todays board!
Dec 10, 2010 | Antec SL300S 300W Power Supply (045176)...
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Power supply
Yes, It is a GOOD IDEA to get a bigger wattage PSU in case that you want to add extras to your HP. No you do not need a new case unless it is beat up, or you just do not like it anymore....
Jan 14, 2008 | HP Media Center m7250n (ED842AA) PC...
Dell E173FP 17" LCD Flat Panel Monitor Logo
187 people viewed this question
Alun Cox
