Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
LE indicater i turn my dishwasher on it is a LG, and after a few minutes it starts beping and in the display box is LE blinking. how can i fix it.
  • 5 Answers
I have had that where the filters are dirty,
check and clean filters at base of dishwasher.
Chris
lg durban
031-7165444
Posted on Feb 02, 2009
How to fix lg dishwasher that has code le
I think you may be getting IE code which relates to water inlet problems. Either the water pressure is low or the inlet valve may not be working properly.
Refer page 21 in the user manual which can be dowloaded from this site
Product Support
But if it is LE code then see this page for suggested fix.
LG Help Product Support and Troubleshooting LG USA
Jul 30, 2014 | LG LDF6810ST Stainless Steel Built-in...
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
AFTER 2 MINUES STARTS BEPING AND SHOWS LE IN ITS INDICATOR
LE error is related to the motor
locked.
locked.
The Blade is locked
I would suggest you contact a repair person
Aug 29, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
MY LG DISHWASHER AND DRYER ARE DUDS
Hello,Sounds like a mechanical obstruction somewhere :->. Possible bad rollers or idler pulley. This could have snapped belt. Need to removed front door panel and lid to get at it. Open the door and rotate the inside drum by hand and see if it moves freely. If it does, you may rollers are probably good. Turn on power and listen for the motor turning on. If you hear a low hum then possible idler pulley or belt issue.LE error on DW - no quick fix here. I heard of wiring issues on the LG's, broken wires, that go from the control panel down to the motor/sensors/etc that result in this error code. I'm not up to speed on the LG dishwashers yet so maybe someone else can contribute.Rich
Apr 28, 2010 | LG DLE5955 Dryer
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
I get error code le on LG dishwasher.
hi,
le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
locked.
locked.
Remedy:
Replace the PCB.)
good luck.........
Mar 12, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
243 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
