Question about Insignia IS-LCDTV32 32 in. Television
No Signal/VGA Input
Wife push a "few"  buttons on side panel controls and no Signal/VGA Input messege on screen...unplugged and plugged back to outlet and cable wire is securely attached...answers?
  • 54 Answers
Use the " input " button on the remote control to select the input you are using to watch tv. she has accidently switched it to the computer input jack which is located on the side.
Posted on Jan 24, 2009
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
I pressed the VGA button on my remote and lost my picture.
Find the button that relates to the input you want to view. IE "video" "composite" "s-video"
Or simply try any of the input buttons until the picture returns.
Also try simply hitting the VGA button again.
If none of that works, please let me know the model number of the tv and the input sources you are trying to view.
May 02, 2008 | Televison & Video
Tip
I have a Proview LCD TV model # PA-32JK1A. When I plug in the TV, the orange...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Jan 09, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony TV problem.
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Mar 06, 2008 | Video Game Consoles & Games
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
How do i connect my pc to my tv
Used the VGA cable came with ur computer monitor,used that VGA cable plug in VGA input it the tv and plug it other end to the computer video card.Used ur tv remote look for a input button pushes look for the mode computer signal in the tv like input 1,2,3..so on.
Feb 12, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Gateway fpd1960 19in. flatscreen lcd monitor has "input analog' across the screen, then goes black. tput new cable on still no picture except when i push input button on the side of panel only for a moment...
checkl in your menu or settings if you have inout it to VGA signal...have you tried other mintor in your current CPU if it works? you can scan the input of the signal from your menu and it should be VGA input.
Oct 12, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Polaroid flm-3232 locked or in sleep mode? Is that...
Try to read your product manual caferfully all information are cited in the manual in order to have a smooth operation of your unit.
Oct 19, 2008 | Polaroid FLM-3232 Television
Polaroid flm-3232 locked or in sleep mode? Is that possible
Hi there!
I work in an electronics store and I've come across this problem before. The only solution that has ever worked for the people who call in or come to see us is pretty simple. You need to unplug your PC from the TV (if you haven't already done so), turn the TV on by using the "channel +" button. Some TV's when turned off at the wall will not turn back on again unless you press the channel + button. Give it a go and see what happens. Let me know if you need more help.
Also, it sounds like your laptop may not have been supported due to the wrong resolution being outputted through your VGA connection. When you get your TV turned on again I'll see if I can help you get them to work together,
Cheers and good luck!
Abby.
Insignia IS-LCDTV32 32 in. Television Logo
206 people viewed this question
Top Insignia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
