Question about GE GSS25SGMBS Side by Side Refrigerator
WATER IN DOOR
WATER IN THE DOOR HAS SUDDENLY STOPPED DISPENSING. ICE SEEMS TO BE WORKING FINE. THE ICE BIN IS FULL AND WILL DISPENSE. CAN'T GET WATER TO DISPENSE--WORKED FINE AN HOUR AGO.
  • 72 Answers
Bad solenoid assembly maybe
Posted on Jul 11, 2007
I have a G E Profile Refrigerator. The ice stopped dispensing and later the water stopped dispensing from the door. The ice maker works fine but will not dispense ice from the door . How do I fix this
Not sure how old your fridge is and the quality of your water; but my service manual says that 3-5 years is the average for most of those units. Regardless of the name on the door, there are only a few manufacturers.
Mine is an all in one unit and, while the dispensing was fine, the cubes wouldn't release. Metal parts corrode and plastic wears.
Sounds like a service call or a trip to the parts store if you think you can do it yourself.
Jan 26, 2015 | Refrigerators
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
Lg freezer ice maker making ice but not dispensing
I have the same problem. I am getting tired of having to clear it out about once a week. I take the ice holder out and empty it in a large bowl and remove any large, melted together pieces, then replace it. It works fine for a while.
Mar 17, 2017 | LG LSC23924ST Refrigeration : Refrigerator...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Our Kenmore side by side refrigerator ice maker makes ice but when we press the ice dispenser lever there is no sound and no ice comes out.
If your refrigerator has an ice dispenser, you are probably used to getting ice right away when a lever or button is pressed. However, if you depress the ice maker button and nothing dispenses, there is an issue with your refrigerator. There are a few different reasons why an ice dispenser would suddenly not work. It is important to troubleshoot your refrigerator first to determine the problem. Some problems can be fixed at home, while others must be repaired by a professional
1 Remove the ice bin from the freezer and press the button on the front of the refrigerator for cubed ice.
2 Open the freezer door and hold down the switch on the door, which "tricks" the freezer into thinking the door is closed, and push the lever or button to dispense ice. The motor behind the ice bin should turn. If it does not, this means the motor is frozen.
3 Remove the motor, following the directions in your refrigerator's manual. Heat and dry out the motor with a hairdryer until the motor turns again, then reinstall the motor according to the manufacturer's directions.
Ice Bin or Chute
1 Remove the ice bin to see if it is overloaded. Ice bins that are too full can cause new ice being produced to back up and cause blockage. If this is the case, dump out the ice and rinse out the ice bin with hot water until any blockage is melted.
2 Examine the separator that divides the ice storage bin from the ice dispenser for holes. If the separator has a hole or is cracked, it must be replaced.
3 Watch the flap on the ice dispenser as you hold down the door switch and simultaneously press the button to dispense ice. If the flap does not close all the way, check for ice blockage and gently remove it. If there is no blockage, the flap will need to be replaced.
Hope this tips would help.
Have a nice day!
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
233 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
