Question about HP Officejet 4110 All-In-One InkJet Printer
Paper jam hp officejet 4110 - HP Officejet 4110 All-In-One InkJet Printer
  • hazel mccrite Feb 08, 2009
    paper jam i can not find paper jaM
I CANNOT FIND PAPER MY PRINTER INDICATES PAPER JAM
Posted on Feb 08, 2009
  • 535 Answers
Clean the roller of your printer if problem occers then u need to change it
Posted on Jan 22, 2009
My printer say out of paper
Turn printer off and on.
Check to see if there is a print queue and then load the papers to end the printing.
Try also turning the printer off and unplugging it from power and restarting your PC.
Plug printer back and connect with the PC and then turn them on.
You can also check for paper jams in the paper paths and manually remove any stuck papers.
Run a print test by:
  • Press setup on the printer menu
  • press 1 and then press 4
  • Press start color/start black.
  • Your officejet now runs a print test.
Hope this helps.Thanks!
Please rate this answer.
Oct 23, 2011 | HP Officejet 4110 All-In-One InkJet...
When i turn my ofice jet 4110 on, rhe yelow light comes on for approximately -3 seconds and is immediately replaced by the flashing red light which stays on no mattr what i try.
There are usually 2 culprits for this. Try these first and they might solve your problem.
1. ink cartridge jam - sometimes the ink cartridge is loose. just remove it and put it back.
2. paper jam (or other stuff) - sometimes some paper/paper clip/ rubber band gets jammed in the paper feed
Try also looking at the PC/laptop which it is connected to. There is a chance that a message will show the actual printer problem.
May 18, 2011 | HP Officejet 4110 All-In-One InkJet...
Hp officejet 4110 all-in-one There is nothing jamming it but continue to get this message.CARRIAGE JAM: CLEAR JAM, THEN PRESS ENTER. I have tried cleaning it shaking it putting oil on rod. You name it...
Hi there
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | HP Officejet 4110 All-In-One InkJet...
Paper will not feed; i have cleaned all the rollers
does it try to pull the paper? if doesn't check the paper sensor, if it does try to pull, you need to clean very well the "pick-up" and the under part. Try using "Thinner", it's very good!
Hope it work now.
Aug 13, 2009 | HP Officejet 4110 All-In-One InkJet...
Says Paper Jam But No Paper In It
Hi
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
HP Officejet 4110 doesn't print
You very well could have messed up a sensor in the printer.
These days, printers are considered "throw-away" and normally there are not any parts available to repair them.
You won't find a manual. Even printer repair shops cannot get parts.
But before you consider all lost, you could try to get a new cartridge. Otherwise, get a new printer.
Apr 20, 2009 | HP Officejet 4110 All-In-One InkJet...
Paper jam, how do I clear it
if u have jam then u have to do this try to clean it if problem occer then u have to change the roller if u have jamed papar in your printer u have open back side dore of your printer then remove the jammed paper
Jan 22, 2009 | HP Officejet 4110 All-In-One InkJet...
Carriage Jam
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Jan 18, 2009 | HP Officejet 4110 All-In-One InkJet...
I need 4110 hp officejet all in one printer driver
HP website. Start here => http://www.hp.com/#Support
It's asking for the correct operating system to download the driver. =>
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%C2%BB
Dec 26, 2008 | HP Officejet 4110 All-In-One InkJet...
Regarding hp office jet 4110 printer driver
get it here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â»
there are three models
HP Officejet 4110 All-in-One Printer
» HP Officejet 4110v All-in-One Printer
» HP Officejet 4110xi All-in-One Printer
do check which is yours and download...hope it helps!
Nov 20, 2008 | HP Officejet 4110 All-In-One InkJet...
HP Officejet 4110 All-In-One InkJet Printer Logo
250 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
