Question about Husqvarna Chain Saw 20" Bar
Jonsred chain saw 455
Very hard to start, gas is running out muffler,put in new spark plug ,but no chance
  • 1 more comment
  • Anonymous Feb 10, 2009
    HI I HAVE GOT A HUSQVARNA 480 CD AND HAVE ONLY JUST HAD IT FROM E BAY AND WENT TO START IT AND FUEL CAME OUT OF THE EXHAUST AND IT WONT START ANY IDEAS CHEERS
  • wildbill6969 Apr 02, 2009
    I have the same problem with my sthil 290 fuel coming out of the carb and wont start
  • Anonymous May 17, 2009
    i have the same problom, new carb m#445
Sounds like the needle valve is sticking open. Could be as simple as cleaning it.
Posted on Jan 31, 2009
  • 6 Answers
I am only taking a educated guess at this but I believe that you have a carburetor or reed valve problem and unless you are experienced at this type of work I can only suggest that you take your saw to a trained technician
Posted on Jan 27, 2009
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Can't get it started after new spark plug (gets spark), new gas, good compression tried starting fluid. Whats the problem?
Quick way to check condition of the engine is to remove the muffler. Also make sure that the spark arrest screen is clean. With muffler off, examine the condition of the piston and cylinder. If the piston looks burned and cylinder is scratched, saw will be hard to start. The cylinder and piston should look very smooth. Secondary test to verify condition of engine is to spray plenty of wd40 in cylinder and around piston, then pull the starter slowly. If you see lots of bubbles as you pull, indicates compression is leaking and will be hard to start. If cylinder/piston are in good condition, use new spark plug and retest.
Oct 18, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Husqvarna 455 starts great and sounds great without pressure but when you put the saw under pressure of cutting it bogs down and runs up and down. I am not sure the problem. I have changed spark plug,...
If you haven't done so already I would run some spray carb cleaner through it. If the idle speed is okay then I would adjust high and low screws going very slowly about 1/16 of a turn at a time and run engine up and down after each adjustment. I would remove the muffler and clean the spark arresstor screen to get all the carbon deposits out of it.Carb. cleaner and a medium stiff wire brush work well for this. I would also check the vent in the gas cap to make sure it is open. I also use a product called sea foam in all my engines.For my chain saws I mix 5-6 ounces with 2 1/4 gallon of gas.It really does a good job of keeping everything internally clean. Hope this helps you. Thanks.
Jul 28, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Need help on chain saw
This sounds like the engine was run without oil in the fuel. Remove the muffler and spark plug so that you can look at the cylinder wall and piston skirt. If these surfaces are badly scored, the compression in both crankcase and cylinder head will be nearly non-existent. This will prevent any intake of fuel into the engine. Replacing these damaged parts plus labor will likely exceed the cost of a new similar saw. Hope this helps!
May 20, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 starts good and idles fine but wont go wide open it boogs down and misses
Here are a few things to consider :
- fresh fuel ratio 40:1
-new spark plug
-choke not sticking
-air fuel mixture correct
-bar and chain oil tank full, oil getting on chain
-bar sprocket in good shape getting lubed.
Please let me know what you find.
Feb 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 Husqvarna chainsaw will not run
Remove exhaust , check piston make shore you have a chance,
check ex screen isn't blocked.
check choke isn't stuck on,and half throttle is working. get back to me from there.cheers
Dec 22, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
286 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
