Question about Superex Electronics - Others
Model 50-306c my inverter turns on but doesn't put out 110 power. what should i check ? where can i get a repair manual. thank don
2 Suggested Answers
cmcduncand
  • 714 Answers
SOURCE: My inverter is in alarm and won't produce 110
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Posted on Jan 30, 2010
I heard a pop like a large electrical component blowing. Now the fan won't come on and the unit shuts down after a few seconds. The consumables were still pretty good but replaces them after the p
Very first thing I would check is for fuses. From there I would put a meter at different points for find out where the power stops. The will identify the component or the area that needs to be repaired. Main power supply is my guess for replacement.
Jan 21, 2013 | Inverter 50a Amp Plasma Cutter, Air ,...
Doesn't turn on
Gain access to the electrical connection with voltmeter set to 110 v ac check for voltage on both sides of switch. If voltage is present on outlet side follow output wire to start relay ck for power on out put side of relay. if power follow output wire to motor if voltage is present replace motor ! Be careful where you touch when probing contacts !
Dec 29, 2012 | Kenmore whispertone 100 model 116
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
Need matco 160 repair manuel
Hi:
Here's Clarke's owners manuals web site, just choose your model and download it.
http://www.clarkeservice.co.uk/product_manuals/mig_welders.shtml
Don't forget to rate me.
Sep 24, 2011 | Clarke Power Products Clarke 130EN...
I have a 700 watt power inverter. what appliances can be used for that amount of watts.
Please understand that an inverter should only be used for temporary use, not like a generator. 700 watts is about the upper limit that most cars or light truck alternators can take.
Before adding loads to the inverter, check the wattage rating of each device you plan to connect. You should not exceed 80% of the inverter's capacity, or 560 watts continuously (.8 x 700).
Some inverters output a pure sine wave, meaning they are suitable for things like computers or other more sensitive electronics. If the inverter outputs a square wave, you should be careful not to connect devices that could be harmed.
If you look on the inverter, there should be a model number and make. It's best to refer to the owner's manual before you use the inverter. If you don't have a book, you should be able to find one on-line if you search by make and model. There may also be a phone number you can call for technical support or to obtain a manual.
Aug 27, 2011 | Vector 800 Watt Digital Power Inverter
Hello, I m working on hp w1907 when press the power button the led stay blue it does not change color but the screen light for a few sec. than shut down.
A component inside the monitor has failed - hardware failure, the monitor will have to be opened and tested to identify it.
The fact that the light appears on the screen shows the fact that the power source and the inverter are functioning - the failure is located in the mainboard. Because the status light doesn't changes color it means that the processor of the monitor is no longer loading the firmware - the damage is too great to be repaired. The board will have to be replaced and that will be expensive: $110 for a new board + the shipping to your location. If you don't have at least a basic experience in repairing electronics a visit to repair shop will cost you another $100.
In my opinion this monitor is not worth this much money: for $200 you can buy a bigger and better new one.
Aug 26, 2011 | HP w1907 LCD Monitor
Power surge while it was turned off. when power was restored 47" vizio lcd/hdtv screen flashed then went black. won't turn on even with vizio trouble shooting steps, repair shop says needs a new...
sounds like you have a bad back light inverter board and it needs to be replaced. if it is still under warranty then try to get the manufacture to repair it for you. just don't tell them its from a possible power surge. check sharp's web site for more info. i think vizio is made by sharp electronics.
Aug 25, 2011 | Vizio Televison & Video
Hello my laptop will not tun on when i slide thepower switch. HELP ME PLASE. PLEASE Thank you VERY MUCH
Check for voltage at the tip of the power connector.
If there's power there, try removing the battery and powering it up.
If that doesn't work, you can try a new power supply, but get a written guarantee that if the unit doesn't work, that you can return it.
If a new power supply doesn't fix the issue, even with a new power supply, then chances are unless you are an electronics technician/technologist, you aren't going to be able to repair the unit yourself.
Most places will want to replace your motherboard - don't use these shops.
Find a place like www.SuperTech-IT.com that does component level repairs and can evaluate and repair the motherboard rather than replacing it.
Aug 08, 2011 | Computers & Internet
I I HAVE A philips 42pf5320/10 IT TURNS ON GREEN LIGHT IS ON BUT THERE IS NO BACK LIGHT, NO ONSCREEN DISPLAY, NO PICTURE.
Hi.
If your TV is LCD this are the procedure/steps to fix your problem.
Half picture on top of the screen, and the bottom half is black it means the back-light of your TV on the bottom is not working.
This are the step on how to find the trouble of your TV:
First, you have to remove the back cover of your TV to see the internal parts inside.
Secondly,after you open the back cover and the internal parts will reveal.Try to find where is the power supply board.It is usually connected to the power cord and it have a AC input that connects directly in you outlet.
It look like this:
This image is not exactly looks like your power supply because you don't indicate the brand name and model # of your TV.
Thirdly,plug-in the power cord then power it ON and be careful,check the output voltage of the power supply using a multimeter (range in DC) ,if it is have a 24vdc for the supply of inverter board.It is the board that gives a high voltage to the back-light of LCD TV.
Fourthly,if the power supply got the reading of 24vdc it means the power supply is good.Then try to check the input voltage of the inverter if it is have 24vdc.
The inverter looks like this:
This image is not exactly looks like your inverter board because you don't indicate the brand name and model # of your TV.
Fifthly, if the inverter have a input voltage please check the output voltage of it.It should have 500vdc so be careful to perform the voltage data in that point because it has a high voltage or hot area.
NOTE: if you don't have voltage reading on the input of the inverter board (24vdc) and the power supply an output of 24vdc,please check the wire that connect to each other.
Sixthly, If the inverter board have a reading of 500vdc on all outputs connectors (it is usually have 4 to 6 outputs).Your back-light lamp at the bottom are busted replaced it.
Or if your inverter board doesn't have a output voltage replace it.
You can buy the parts here:
Just click this direct link. http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=SFNT&Store_Code=EU
Or here:http://www.shopjimmy.com/
And also to eBay.com at your search engine.
Reminders:
If you don't have any basic knowledge about the electronics and testing equipment please don't attempt to do this steps.Its better to send it to the qualified technician or on the authorized service center of your TV.
If this solution will help you to fix your problem,please don't forget to vote and rate my answer.Thank you and good luck
May 08, 2011 | Televison & Video
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
Electronics - Others Logo
Top Superex Electronics - Others Experts
Are you a Superex Electronics - Other Expert? Answer questions, earn points and help others
