Question about Vacmaster VP112 commercial vacuum sealer
When seal is done air still in the bag
I've got 35 on the vac side and 7 on the seal but the air is not vacuum out of the bag
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my vacmaster pro 90 is not vacuuming
please test if the :a) hose is clogged b) bag/tank clogged or full you need replace or emptied
2) test the belt for broken or wonr, and replace.
God bless you
Posted on Jul 14, 2012
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
Tip
Safe way to vacuum drywall dust
SAVE THAT VAC
One of the hardest things on a shop vac is drywall dust. It is so fine that it gets through the regular filter and destroys bearings/bushings and ruins the motor. Just the other day, a friend commented that he had to get a longer hose as his vac was blowing out a lot of drywall dust because the filter was slipping down!
High performance filters are available at most hardwares and box stores. They resemble the paperbag filters in carpet vacuums and catch the drywall dust so that the bag can just be thrown away when done. The bag is U-shaped to install in the shop vac and have clearance around the regular cartridge filter. The inlet has a rubber seal that pushes around the inlet on the inside of the tank. Just run the vac normally but spare it and your lungs!!!
on Mar 02, 2010 | Vacuums
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
My windsor sensor 12 inch vacuum is to hard to push. I bought a new one and its doing the same thing. My vacuum repair man says he cant fix the problem. My shoulders are sore from working so hard. Help
It\'s possibly the type of carpet you\'re using it on. The sensors use the brush speed and the amount of air flow to determine carpet height. Some berber, and tweeds make these things horrible to push. We sell sebo, who make the windsor and we\'ve had the same issue on random carpeting. We end up selling the G- Series units in these situations because they adjust manually so not to suck themselves tight to the floor. Sebo/Windsor make amazing products but there\'s just no helping this, it happens sometimes.
Happy Vacuuming!
The Vac Dr.
The Vac Dr is always happy to help. If you\'re having trouble finding someone to help contact us here.
Jul 20, 2012 | Windsor SR12 Sensor Bagged Upright Vacuum
My vacmaster pro 90 is not vacuuming
God bless you
Jul 13, 2012 | Vacmaster Pro 90 Vacuum Sealer
Replacing belt
Hello Cheryl,
Please see detail instructions here.
Good Luck,
Rocky
Nov 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Vacuum bag is always says it's full even when is new
You very likely have a defctive control valve under the dial on top of the vac , or a kink or blockage in the tiny pressure hose that feeds the air from the throat of the vac or the back of the bag chamber against the two sides of the rubber diaphragm inside the valve.
You can inspect the tiny hose ports for blockage and clean them with a fine piece of wire. To access the control valve you will open the bag chamber door and slide the bumpers forward with their internal locking keys with a pair of pliers. Once removed the body will open like a **** shell front to back. The control valve will likely have a crack in its threading and can only be replaced with a genuine part available at an AERUS Electrolux store. The fix is a most often a new valve.
This vac is the RUBIKS cube of all vacs. It reassembles with ease when all wiring and tabs are perfectly aligned, so open slowly,upside down , wheels up , mark your wiring and take your time reassembling.
When it all clicks EASILY together without the bumpers, you have it done right
Dec 23, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacmaster VP112 commercial vacuum sealer Logo
51 people viewed this question
Top Vacmaster Vacuums Experts
JoeVacs
Are you a Vacmaster Vacuum Expert? Answer questions, earn points and help others
