Question about Lexmark C533DN InkJet Printer
Reset ink levels lexmark s508 - Lexmark C533DN InkJet Printer
exspert
  • 55 Answers
SOURCE: ink level reset
if you are useing a refilled cartridge , ink cartridge has a chip built in that must be reset, if you look on line you can purchase a reseter. if you use a new ink cartridge it will show a full ink level
Posted on Jan 15, 2008
IB4G2008
  • 3587 Answers
SOURCE: Lexmark x5470 all in one printer-low ink level
we have a link on how to fix your own printer through this link(check for search box further down page)
Posted on Mar 20, 2008
sifon
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
921
Posted on Mar 03, 2009
  • 15 Answers
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Posted on Jul 13, 2009
pineworks
  • 4041 Answers
SOURCE: need to reset ink levels on printer (lexmark 2600)
Hi
It is the chips on the inks that make it shore empty nothing you can do about it.
But I have found this bit of read up on the internet forum Gave it a go may work if it works come back let us know so I can pass it on to others Thanks.
1 Take a small pice of clear tape. Try covering one of the outside vertical row of contacts at thr front of the cartridge. Re-insert it and it shoudl "fool" the printer into thinking it is a new cartridge. It works for my Lexmark 2600 series all in one.
2 Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
3 I had fully covered the contacts because it was the full length of my Scotch tape. It did not work. I went back and re-read thread, wiped the contacts the computer was telling me, took off the strip and put on just a sliver covering the left vertical side of the contact only. It worked! Yippee! Thanks a million!
Go to this website to see all
You can go to this link to see all the read up about it.
http://www.fixyourownprinter.com/forums/inkjet/35235
I not have this printer myself so I not can say if it works or not.
All The Best Hope it works for you
Posted on Jan 31, 2010
Reset ink levels
Please note that once a Lexmark cartridge is refilled, it can no longer register its ink level.
Also, Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 21, 2012 | Lexmark X Office Equipment & Supplies
After refilling Lexmark ink cartridge, ink levels donot show full. Reset ink level?
When you refill your cartridge, the cartridge will no longer be able to register its ink level.
Apr 06, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark X2550 ink cartridge refill
-Mustafa
Mar 31, 2009 | Lexmark X2500 All-In-One Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
Maybe you can try to rest the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
Mar 05, 2008 | Lexmark X2470 All-In-One InkJet Printer
Ink level reset
Jan 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
