Question about Activision Shanghai: Second Dynasty for Windows
Shanghai 2nd dynasty doesn't run on my intelmac on win xp
I use parallels to run Win Xp professional. It is possible to install the game, but it is impossible to start.
3 Suggested Answers
  • 285 Answers
SOURCE: drakan order of the flame engine crashes
You could try installing the DirectX version the game uses. (probably on disk)
You can also try to download this Windows Virtual PC.
Windows Virtual PC emulates Windows XP on your Windows 7 PC, so that you can run older applications that won't run on Windows 7 otherwise.
You will however need a processor capable of virtualisation.
Virtualisation check and download here: http://www.microsoft.com/windows/virtual-pc/download.aspx
After installing Windows XP Mode you will need to install the game again in this XP emulator, but after that it should run fine.
I hope this helps,
Yannick.
Posted on Dec 08, 2009
  • 395 Answers
SOURCE: Hey, I just moved from
THPS2 only works with windows 95/98/ME/ and XP 32 bits, it won't work with Windows 7 either 32 or 64bits. The terms 32 bit and 64 bit refer to the way a computer's processor handles information. The 64 bit version handles large amounts of random memory more effectively than 32 bit system. That explains why yours THPS2 doesn't work on your new windows 7 64 bits.
Posted on May 15, 2011
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
HELLO!PLAESE HELP ME.I HAVE dell vostro 1015 windows vista but i want to convert it into xp,the problem is whenever i try to install windows xp a blu screen appears saying that something about my bios
Are you using a full version retail or OEM copy of WIN XP to install? Or is it a recovery copy from another PC or laptop? You will need to use a full version disc to perform the retrofit. You will also need to download the WIN XP Drivers for your laptop from the Dell Site. You CANNOT "upgrade" install WIN XP over VISTA and keep your drivers, settings, files. Performing a WIN XP install will require a total wipe of your hard drive. Therefore you will have to save off all your personal files before you do this. Microsoft doesn't provide assistance for downgrade-type installations, so you must basically wipe your hard drive and then reload the OS.
Jan 07, 2012 | Dell Vostro 1015 Laptop
Am looking at buying a friends 320 scanner, He cant find the booklet or cd 4 it. also doesn't have the parallel cable eather. Can i get this from the company? Also I havw windows xp. will this work on...
First you would need to make sure you have a parallel port on your computer, because if you don't, you would need to get an adapter of some sort for either a p2p or usb port, whichever you prefer. I'm not sure if you can get a parallel cable from the manufacture, but you could probably find it on eBay. With an older scanner and a newer computer, you can probably just plug it in and it will work, but if you need the software, go here: http://www.nodevice.com/driver/320P/get25293.html
Hope this helps!
Aug 25, 2011 | AcerScan 320P Flatbed Scanner
I am running win-7 x64. Is there a driver I can use for my Agfa flatbed scanner snapscan e25?
Hi koppeling
There is no direct solution since Agfa doesn't support your driver anymore after XP .
Install a virtual version of XP on your PC with FREE WmwarePlayer :
http://download.cnet.com/VMware-Player/3000-2094_4-10470784.html or via Microsoft if you are using Ultimate or Professional .
Otherwise , you 'll need to replace your device by a W7 compatible one .
best regards ,
fanaudi .
Aug 23, 2011 | Agfa SnapScan E25 Flatbed Scanner
Dear Sir I am installaing WIn Xp Professional 64 bit on Intel motherbaord DH 61 WW with 8 GB corsair ram and after the boot hardaware error occurs and its ask to check the hardware or viruses...
The motherboard has nothing to do with your problem. Its your processor it has to be a 64 bit processor. If you don't during the installation you will get an hardware error. Your windows 7 must of been a 32bit or aka 86x platform. So put windows 7 back on (recommended) or try windows xp pro 32bit
Aug 11, 2011 | Intel Desktop Board DH61WW Classic Series...
Where can I buy a copy of Activision Shanghi 2nd Dynesty that will run on Windows XP
If you already have it, there's a fix to get it to work
http://activision.custhelp.com/cgi-bin/activision.cfg/php/enduser/std_adp.php?p_faqid=7948&p_created=1008608410&p_sid=_cDKUSzk&p_accessibility=0&p_redirect=&p_srch=1&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzM3LDMzNyZwX3Byb2RzPTAmcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9U2hhbmdoYWkgMm5kIER5bmFzdHk!&p_li=&p_topview=1
Jul 19, 2011 | Activision Shanghai: Second Dynasty for...
Can sony vaio VGN-FS742/W run windows 7?
Yes the Sony should run Win 7 although its designed for XP. For Win 7 to run properly you will need to max out the memory to 2GB.
I have installed Win 7 on plenty of older laptops without any problems. You won't be able to use the aero glass features (see through taskbar and window borders) as the graphics chipset doesn't support that feature but everything should work well once you have enough memory installed.
Regards.
Apr 21, 2011 | Sony VAIO VGN-FS742/W Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Task manager in win xp keeps blinking, it will not closed, no matter what i push nothing, plus win xp keep freezing any solution how to fix this problem
VIrus infection?
to check and secure u need:
win-xp cd or other bootable win-cd, seperate up-to-date antivir software on cd or usb-stick,
your passwords
procedures:
boot system from cd/dvd (do not bother if screen resolution is different from usually),
exit windows-setup,
insert antivir-cd or stick, run full system scan.
found infections? remove/erase these files(antivir will do that for you)
if possible, back-up personal data (my folder, music, save games, etc.)
this data has to virchecked by another protected system before reinstallation !
boot from win-xp cd-rom, run setup until repair options are available,
repair your xp on harddisk(xp-will do that mostly), exit setup without installing win xp anew
boot system from hd, ignore error messages, run vircheck again.
if you're lucky, this will do, else lemmie know
Jun 13, 2009 | Dell Inspiron 6000 Notebook
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Activision Shanghai: Second Dynasty for Windows Logo
43 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
