Question about Car Audio & Video
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
When connecting my ipod or even a USB onto the unit it connects but there is no sound. Ive resetted the unit & checked the cables various times. I hope you can help
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
not getting any sound from my i-pod Pioneer AVH-P4 - 1_6_2016_11_06_35_pm.jpg
Posted on Jan 06, 2016
c renner
  • 43 Answers
SOURCE: Using Aux Input in a Pioneer AVH-5700DVD
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
If you've done that - you need to go to the initial settings menu and set aux input to 'on'. Instructions are in this link, page 89.
Posted on Feb 29, 2008
SOURCE: ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
Posted on Aug 06, 2008
SOURCE: Pioneer AVH-P4100 Ipod Video not playing
You have to set up the AUX output.
1. Touch the source icon and then touch "OFF" to turn the unit off.
(The unit will be in demo mode)
2. Touch the screen to display the touch panel keys.
3. Touch AV Menu you should see "Inital Menu" and touch it.
4. Touch AUX 1 on the inital menu to select desired setting.
5. Touch it until Ipod is selected (make sure you have the CD-IU200V connected.
6. Touch ESC. Ipod video should work now.
7. See Page 50 in Operation Manual for more information.
Posted on May 22, 2009
SOURCE: I have a pioneer avh-p6500dvd I was playing a dvd
I have the same problem, it seems that the Integrated circut that controls the CD stoped working.
You'll need to go to a repair shop and replace it.
Posted on Aug 22, 2009
SOURCE: I HAVE A PIONEER AVH-P5100DVD AFTER CONNECTING ALL
make sure u have connected the fm tunner silver box if not thats your problem if u do not connect it it wont power thats really important.
Posted on Oct 08, 2009
How to connect ipod to the Avh-p5700dvd
You should connect the cable to the audio in. You will then need to change input(source) on the radio to auxilary. Good Luck.
May 27, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I cant play ipod video thru pioneer avh p 3100
Select the Source menu, press the OFF key, touch the screen and select AV MENU, and select initial, then touch AV input 1 until it says I-Pod.
Nov 05, 2009 | Pioneer Car Audio & Video
I have a pioneer AVH-P4100DVD receiver and I have an i-pod touch. I connected it to the head unit w/ the CD-IU200V cord and I can here music but I can't watch my movies off of it.
Shut the radio off. Touch top right of screen. Once done, hit AV Menue. Initial Setup. AUX1. Switch to Ipod. Once done should work. If not make sure the 3mm jack is plugged into the aux input into the back.
Oct 17, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Background pics
On the AVH-P4000DVD you can NOT set your own jpgs as a background image. You are allowed to do this on the P4100.
I have read that you can view images if you are using an IPOD with the IPOD connection in the rear of the 4000, but you have to leave the thing connected at all times to see the pics.
Aug 07, 2009 | Pioneer AVH-P4000DVD Monitor
How do i play video from usb on a Pioneer AVH-P4000DVD?
You can NOT view video using USB on this unit. Video has to come from the AV inputs (RCA connections) or from an IPOD connection. Sorry.
Jun 30, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod problems on my pioneer avh
To be working the ipod need to be hook up with the cable cd-1200 (not sold with the avh)and to be plug to the ipod plug on the back of the radio..if you plug the ipod on the usb it wont do..the cable is around 30 $ ..it is the good way to play your ipod ..but if you have a ipod touch 2 generation like i have it wont charge ..if you have any other ipod it will be charging when in use..
Mar 04, 2009 | Pioneer AVH-P4000DVD Monitor
Cannot get my I-pod touch to work with this unit
I'm having the same problem, have you been able to solve it yet?
Jan 04, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod will not play video to my head unit AVH P5900DVD
May 24, 2008 | Car Audio & Video
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
317 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
