Question about Philips DVR-1
Philips DVDR 3506/37 - when in stand by mode -
There's a high pitch squeal coming from the disc tray area. When player is in the "on" position, squeal goes away. Is this noise normal?
I had the same problem, it is a Diode on the Power Supply Board. The Location number is D1054, you should change C1051 also. It maybe leaky. I used a 10v 1000uf capacitor instead of the 6.3v 1000uf it had. Make sure to be careful when changing these components, making sure the polarity is right. Good Luck!
Posted on Sep 12, 2009
I have a dvdr 615/17 with a disc in the dvd and the door will not open. The info window goes from opening to closing but the dvd never opens .
Mine does the same thing. Press eject then press and release the face of the tray. I have also had luck with gently prying a corner of the tray face after pressing eject. One other is once you get the tray out, remove the tray face.
Daddy long legs.
May 10, 2010 | Philips DVDR615 DVD Player
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a phillips DVDR model#3455H.Inserted dvdrw disc recorded with videos recorded on it in my computer. Disc works fine in my pioneer dvdr but when I put it in the phillips it will not load and it will...
The electronic procedure:
Switch off the unit at the wall plug. On the front panel, hold in the <RECORD> and <EJECT> buttons at the same time, and keeping them held, switch on the power at the wall again. Keep holding the buttons until the disc tray opens.
Apr 03, 2008 | Televison & Video
Philips dvd783c wont spin.
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Mar 31, 2008 | Philips DVD783CH Multi-disc DVD Player
Philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Mar 23, 2008 | Philips Magnavox DVD/VCR Dual Player
Player won't function
The Lazer is dirty open it take a ear bud then apply alcohol to bud wipe Lazer gently normally you can use nail polish remover to clean
Mar 03, 2017 | Sony DVP-NC655P Multi-disc DVD Player
Philips DVR-1 Logo
206 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
