Question about GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher
Top rack slider
I have the GE Adora Quiet Power and we've been having a problem with sliding the top rack in. We purchased a new basket thinking it was bent, but did not fix the problem. It stops dead when pushing it in. We cannot figure out the problem.
    Scholar:
  • 84 Answers
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Posted on Jan 22, 2009
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
GE Quiet Wash 3, top arm does not spin
It sounds like you don't have enough water. Your water inlet valve may be not letting in enough water or the plastic pump inlet screen located on the bottom of your dishwasher had something blocking it.
  1. Check to see if there is something blocking the plastic screen on the bottom of your dishwasher.
  2. When your dishwasher is in the final cycle add a pot of hot water to the dishwasher and see if your dishes come out cleaner.
If the dishes come out cleaner you may need a new water inlet valve.
Dec 29, 2009 | General Electric Adora GHDA670N Built-in...
Replace wire baskets in freezer, the model I purchased only has wire shelves. However, in the store i tried the baskets from the GE Adora 29 cu ft and they worked fine.
Get the actual model number from the refrigerator with the baskets. Then go to the Sears parts website at www.searspartsdirect.com. They have exploded views and parts available for a lot of appliances, and you should be able to get the part number and price for replacement baskets. Once you have a part number, you can do a Google search for that number to locate other suppliers and shop around for a good price. Or you can just check at the store where you purchased the refrigerator about ordering the baskets right through them.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Nov 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Adora Dishwasher Upper Rack Binding Issue
I have a GE Profile model PDW7800.... and just replaced the rollers on one side since one of them had broken. There is a 'magical' way to reinstall the rack so the side guides ride inside the roller guides without touching. I suspect that the rack has not been reinstalled in the precise manner - which I am still trying to figure out. The new roller assembly which attach to the rack fit differently than the original ones. I found that you do have to remove the rollers screwed into the wall to get the glides out and that could also cause rough gliding. Part of the 'binding' is designed, I believe, to keep the racks from coming out too easily.
Sep 17, 2008 | Dishwashers
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Nov 05, 2007 | Baumatic 24 in. BFD60SS Free-standing...
GE Adorda dishwasher
This one is a known issue and an easy fix. Use a tie wrap to securely tie the water tube for the middle spray to the upper basket. That's it. Believe it or not, it's that simple. You may want to secure it at the front and the back. To test this you can use the tie wraps used to closed the plastic grocery or bread bags. If this solves the problem you can buy a bag of nylon tie wraps from any hardware store. I had a similar problem with another GE model with a similar problem. The dishwahser used to make a horrible grinding noise during the wash cycle. One I secured the middle sprayer arm the grinding noise went away.
Sep 20, 2007 | Dishwashers
GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher Logo
188 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
