A E G lavamat 76820 fault codes e120
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
May 27, 2014 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 11842 Error code E66
http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
Feb 23, 2013 | AEG Washing Machines
I have a AEG oko-lavamat 75520 update. It stopped and the code C9 showes on the display. What does the code mean, and is this something I can fix my selfe?
Hi Mrs Willems from retired Englishman in SW France,
According to my list, AEG Lavamat 8*** Series Onwards C9 stands for 'tacho fault' (monitoring the motor speed) requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Washing Machines
AEG Lavamat 88830 Update Gives me the code C7. Whats wrong?
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
Nov 09, 2010 | AEG Lavamat 88840 Front Load Washer
How to deactivate EFO on Lavamat 76819?
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 03, 2010 | AEG Lavamat 74640 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Cannot find drivers Lexmark e120 for windows vista
You can download driver from below link.
http://www.nodevice.com/driver/E120/get32704.html
onece you go to above link ,scoll down page put the code in the box and click on download,it will say that downlaod will start in 15 sec
Hope it can resovle your issue
Thanks for using Fixya
Apr 09, 2010 | Lexmark E120 Laser Printer
Lavamat
have youlooked in your manual it should have some codes in trouble shooting that will help you sort out the problem. hope this helps.
Jun 01, 2007 | AEG Lavamat 12710 Front Load Washer /...
Washing Machines Logo
Top Washing Machines Experts
