Question about Veho Muvi Micro Dv Camcorder The Smallest Dv Camcorder
Muvi HD card won't stay in
The SD card won't stay in the slot. It keeps popping out and says that it's not reading the card unless I hold it in with my finger. Please help!
Laptop won't read SD card
have you been tried to use other sd card ? or have you been tried to use other usb slot of the laptop just to know if where the main cause of the problem.
Mar 25, 2013 | Acer Aspire 5736z 4460 Laptop
Toshiba u205 - SD card won't stay in reader
Just buy an external SD card reader that plugs into one of your usb ports. You should be able to get one at any local pc shop or best buy.
Aug 17, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 | Cameras
I'm having a problem with the sd card 8gb. i get a check card error and it won't function.
The SV-AV30 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Jul 27, 2012 | Cameras
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
PNY optima sdhchd 8gb won't read in my Kodak easy
What model Kodak EasyShare camera? Some of them only work with SD cards, not with SDHC cards. The same applies to kiosks. Make sure the slot is marked "SDHC' and not simply "SD".
Feb 05, 2012 | SanDisk Cameras
SD slot won't read card
I had the same problem. You have to buy the specific card for that SD slot and it has to be an original one. Mine worked with the Micro SD 4gb.
May 09, 2011 | Car Audio & Video
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
Veho Muvi Micro Dv Camcorder The Smallest Dv Camcorder Logo
Top Veho Video Cameras Experts
Are you a Veho Video Camera Expert? Answer questions, earn points and help others
