Question about Koolatron P25 26-Quart FunKool Cooler, Dark Grey
Not cooling i replaced the fan already
Fan runs but is not getting cool
  • 17,129 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off. If not the auto defrost timer, or the thermostat must be checked.
The ventilation fan that circulates the COLD air from the evaporator coils could get clogged with frost and so could be jammed. Also the wires to the fan can be worn out due to the frost. If so check if the defrost timer works to switch the heater to remove the frost. Also the check if the compressor is shut down by the timer /thermostat . If the heaters are not working, check continuity of the heaters.
So attempt to test using a multi-meter / clamp tester from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for using Fixya.
Posted on Jan 12, 2013
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
Chevy cavalier questions
Sounds as if,the cavalier,may have an internal blown head gasket.
Apr 29, 2014 | 1999 Chevrolet Cavalier
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
Electric fans run alltime and tempgauge stays on cold .already replaced coolent sensor.
You need to have the cooling system serviced. Drain the coolant, replace the thermostat which is more than likely stuck open, flush the system, and refill with a 50/50 mix of the correct antifreeze and distilled water. You may also need to replace the thermal sensor for the cooling fan if it stays on all the time. Know that when the A/C is on, the fan runs continuously. So make sure the A/C is turned off.
Dec 21, 2010 | Chrysler Town and Country Cars & Trucks
My computers cooling fan keeps speeding up and slowing down is that a good thing or a bad thing
I'm assuming your desktop has an AMD processor?
AMD have a process called "quiet and cool" this basically speeds up the fan when the processor is under load and getting hot or slows it down when the processor isn't working as hard.
Regards
Mike
May 26, 2010 | Dell Inspiron 531s Desktop Computer
Replaced relay, but both electric fans won't come on
Are we talking about the cooling fans for the engine and AC condenser?? Only one cooling fan will cycle on and off during normal operation. The main cooling fan will cycle on and off as needed for cooling the engine. If you turn on the AC or select a defrost mode on your climate control then the 2nd additional fan will run usually continuously in order to condense the freon in your AC system for cooling the interior of your car and in defrost mode it helps to reduce interior moisture on the glass (defog/ defrost). If no fan comes on at any time whether the engine is hot or cold or whether you turn on the AC or not and you have already replaced a cooling fan relay and checked related fuses then either the fan /s are bad or you dont have power in or out of the fan circuit which consists of several components that would need to be checked. Let us know if you find anything else or have additional questions.
Apr 25, 2009 | Hyundai Motor 2000 Tiburon
Cooling fan won't come on
if you already replaced the thermostat, then check if both fans where running when the a/c on or if it is just one fan on the condenser is running. if the only fan running is on the condenser try to check the connection of the thermostat then also check the fan of your radiator if it is still running.
Mar 21, 2009 | 1998 Ford Mustang
Cooling fans will only turn on if engine is off only
Electric cooling fans do not run all the time. They will only come on if the engine exceeds normal operating temp. Also will run when AC is on. Easiest way to make sure they are operating properly is to first verify they run when the AC is on. Next turn the AC off and run the engine at 2500 rpms sitting still and monitor the temp gauge (don't let it get into the red). The fans should come on after 10-20 minutes (depending on outside temp.). As the engine cools down they will turn off.
Jan 04, 2009 | 1995 Honda Accord
Cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Jul 30, 2008 | 2000 Pontiac Grand Prix
Koolatron P25 26-Quart FunKool Cooler, Dark Grey Logo
94 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Jerry Kramer
Jerry Kramer
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
