Question about Poulan Garden
POULAN RUNS GREAT THEN DIES WILL START UP AGAIN THEN ABOUT THE TIME YOU START TO CUT WILL DIE AGAIN AND KEEPS THAT UP
  • 3 Answers
I hope you are using fresh gas, as when gas gets old from previous season use, it can be the problem. I have seen a spark plug fouling, giving the same results though. I don't know the hours you have run the saw, or the severe use it may have seen. Have you checked air cleaner? fuel supply? If it was set up for a long period of time with old gas, carb may need cleaning.
Hope all these questions stimulate some possible problem resolution
Posted on Jan 13, 2013
jgwhomeequip
  • 1902 Answers
SOURCE: Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Posted on Feb 16, 2009
  • 211 Answers
SOURCE: Poulan 295 chainsaw won't start when warm
Hi
Check the spark plug first (when the engine has warmed and died).If you have a good spark,check the fuel pump from the carb(it shuld not to be tighten).If everything is ok check the seals(they are sealing the engine).Good luck!
savumihai71
Posted on Dec 11, 2008
  • 36 Answers
SOURCE: poor performance at hi revs on poulan 3314
Try turning the high idle screw out 1/8 to 1/4 turn refer to your manuel for the location of this screw.
Posted on Jan 10, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan 2450 chain saw which runs great
It does happen they quit when hot. More often they just quit.
There are 7 different "2450 Gas Saw Types" here: (Type 1 $25.35)
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
There is a help link on top that will eventually find someone with a pulse. If you go this way please have your saw within easy reach before calling. HTH
Lou
Good for you on the spark test and isolation of the problem. You also listed the make and model. I think I'm in love, LOL.
Thanks, it makes our help easy.
Posted on Oct 19, 2009
Testimonial: "It appears the spark plug was the problem even though I was getting spark. Just ran it for 20 minutes with a different plug. Runs great!!! Thanks "
  • 3 Answers
SOURCE: 20" poulan chain saw cuts at angle
Buy an oregon green chain for the saw,much better chain, more teeth,heavier duty,outcut the original chains by far,and can be sharpened many times over.Keep the chain sharp and she should cut straight.Dont over tighten the chain, I tighten mine til I can just lift the bottom of the chain almost completely out of the bar groove.
Posted on Jan 15, 2010
2005 seadoo jetski wake
Check your exaust hose. Mine came loose inside the engine compartment and it caused the same problem. Would run great for a while, then just die or start sputtering like it was missing or the plugs were bad. After I let it sit for a while it would start up fine, run great for about 15 mins, then have the same problem.
Jun 20, 2013 | Boating
Poulan Twist N Edge TE 450 CXL - has ran great for 10 years. It still runs great and fires right up every time - except now it will run for about 8-10 minutes, then it will just abruptly die. It then...
Hello, W/D here.
Check the pinhole vent in the fuel filler cap. As fuel is removed when the engine is running, air is pulled into the tank. If the vent is blocked, a vacuum is formed, and fuel cannot flow. After a period of down time, air infiltrates back into the tank, and the engine can be re-started. You can test this out just by cracking the cap open after starting the engine, just enough to allow air to get into the tank.
Best regards, --W/D--
May 02, 2011 | Poulan 17" T&E Gas Trimmer
My dodge dakota 4.7 starts without any problem and runs great for approximately one minute. It then starts floundering and will die. You can turn it off or wait for it to die, and restart it and it runs...
Sounds like you have a restricted fuel filter that is causing your vehicle to start sputtering because it can't meet the engine's demand for fuel and then dies when fuel is depleted. After your vehicle stops running, fuel starts seeping by and you can start it again with ease hot or cold and you get the same results moments later if this sounds right replace your fuel filter.
Mar 30, 2011 | 2003 Dodge Dakota Club Cab
Mtd pro snow blower runs then die
it sounds to me like either the oil pressure switch is being plugged after startup and causint the engine to quit then the plug settles until you start it again and it plugs again easiest way to test is to take the swith and remove the wire to it and see if the engine starts and keeps running, if so then replace the old pressure switch. If this does not solve the problem then the only other thing I can think of is the needle valve is partially pluged, at startup the fuel bowl is full and the engine startsbut after starting the fuel bowl runs low on fuel as it is not filling fast enough and the engine stalls. By the time you try starting it again the fuel bowl is filled again and the whole thing starts all over. Hope This Helps Don
Dec 08, 2009 | Garden
My KX 250 keeps dying on me
try nexted hottest plug for ex. i had a b8eg standard and went to b7eg
Jul 11, 2009 | 2003 kawasaki KX 250
2000 s10 Blazer dies very 3-6 weeks for no reason
i would check your ignition system. you would need a meter for this but look for broke or loose connections. if it was a fuel problem i dont think it would just start up after 20 minutes. or you might try your ignition switch. if its shorting or something then ya well it would cut your engine off real quick
Mar 20, 2009 | 2000 Chevrolet Blazer
34 cc Poulan,dies out when tipping it to side to cut tree.
I would check the fuel line for a pinhole or crack.It may need replaced.
Mar 14, 2009 | Poulan Pro Chain Saw 46cc 20"
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
517 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
