Question about Generic Memory USB-Powered Silver Acrylic Notebook Cooler Pad (CPS01SIL) PC Notebook
Generic Laptop Won't Boot Up
Hi Sir,
I have a 2-year old P4, 1.8Ghz Centrino generic laptop having a model D23-T label and uses a Toshiba AC charger. Upon pressing the power button, it won't boot up anymore; the power and battery LED indicator is just flashing alternately. I have already replaced the memory module with a known good one, then removed the hard disk and DVD ROM drive but yielded the same result.
Any help or comment would be greatly appreciated.
Thanks in Advance,
Toynaruto
    President:
  • 1,990 Answers
You are going to have to send it in for Repair. Your Version of Windows Embedded has been Corrupted and they will need to Reload it.
Posted on Jan 22, 2009
Ressette bios password toshiba g20_123
If it is an old laptop, removing CMOS and putting it back might work..try it..else you might have to show your laptop in authorized toshiba service center
Apr 06, 2014 | Toshiba Qosmio G20-123 Laptop AC Power...
My old T200 toshiba laptop not working
Hi Kaiden,
It is an old dinasor of a Laptop, and It sounds like it's dying or dead.
Time for you to update and get a newbie or refurbished Laptop from your nearest PC shop or ebay.
Never use generic power adapters with PCs & Laptops, that will kill them as well.
Always use the recommended power supply, no ifs or buts.
Cheers,
Peter
Feb 24, 2013 | Toshiba DynaPad T200 Laptop AC Power...
How to change toshiba 2000 booupt priority
try holding f2 f10 or f12 this will require up to 3 reboots to figre which one but just hold down one of thse during startup
May 20, 2012 | Toshiba Portege 2000 Laptop AC Power...
I have a Toshiba U500 00X laptop with 19V power supply which I do not have with me at the moment. I do have an ASUS 19V AC adapter with positive terminal on the inside of the circular plug. The diagram on...
Hi, what your toshiba laptop model and asus laptop model? You can use the asus ac adapter on your toshiba laptop only if the folllowing three conditions are met:
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
For the specifications of the two adapters, you may check it here:
http://www.chargerbuy.com, then decide if it will work or not.
Jul 07, 2011 | Computers & Internet
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Hi. good day i have the problem with my charger.it
If you're sure the adaptor isn't powering (recharging) the battery then you will have to replace it. You can do a search and go to toshiba's site to order one, or through a local shop, or you may be able to locate a generic that will work. If you go for a generic though, make sure it matches the laptop. Not all chargers are the same. Also make sure it isn't the connection on the laptop itself that is bad. Some models of toshiba had the tendency for the jack connections to break inside (soldiering etc)
Mar 20, 2011 | Toshiba Satellite L500 Series Notebook
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
My ACER 5920 will not boot up when the charger is plugged in th
Dear Sir,
By analysing your problem it seems to be your adapter dead.So first check your adapter,so your laptop battery may not have backup to turn on the laptop.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Generic computer won't boot up
Have you tried removing the main battery and the cmos battery for about 30 minutes?
Jan 22, 2009 | Acer TravelMate 2300 Notebook
Generic Memory USB-Powered Silver Acrylic Notebook Cooler Pad (CPS01SIL) PC Notebook Logo
65 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
