Question about Philips Audio Players & Recorders
I have a Philips CDR-770 CD Recorder. When I insert a laser lens cleaner CD, the unit says there is no CD in the draw. I have tried 3 different manufacturers of laser lens cleaner CDs with the same results. It works fine with empty, unfinalized, & finalized CDs but not the lens cleaner CD. Is this a common problem with this model CD Recorder? Is there something that will work to clean the laser lens? Please let me know. Thanks.
  • anthonytucce Jan 22, 2009
    If the lens needs to be replaced, why does the lens read and record all other CDs and functions properly except when a lens cleaner CD is inserted?
    Genius:
  • 1,175 Answers
If it works fine on finalized CDs, it's not the lens.
Instead of the "lens cleaning CD" try shooting a few shots of "Dust off" compressed CO2 style stuff into the player mechanism.
That will work better than the CD version cleaner
Posted on Jan 22, 2009
    Genius:
  • 1,665 Answers
I think your does not need to be cleaned. If you want anyway you can use a special lens cleaner or take it to a service shop to avoid any damage.
    Master:
  • 416 Answers
1.You night put the CD cleaner upside down
2. Try to get genuine Philips CD Lens Cleaner ($6 at Walmart)
3. You can clean the lens with cotton swab and 50 % isopropyl alcohol (around $1 in Pharmacy) or laser lens clening liquid.
Good Luck
  • Grigory Zyryanov Jan 22, 2009
    Please tell me the differnce between Q-Tip and some Rubbing Alcohol
    and cotton swab and 50% isopropyl alcohol. I think they are the same
    President:
  • 1,990 Answers
Welcome to Fixya! You don't need a new Lens. This a Delicate Procedure But, You will need to get to the Lens whether you need to Disassemble the Unit or What. Get a Q-Tip and some Rubbing Alcohol and Clean the Lens and you should be just Fine.
    President:
  • 2,110 Answers
It seems that your lens needs to be replaced..
I have a philips cdr 802 that works ok on the 3 disc side, on the recoder side the disc spins when inserted but can not see the disc has the lens burned out. regards john
Warning!!!! do not look straight into the laser it will damage your eye!!!! If you want to see if the lens is on place a small bit of paper over the lens then from a distance of a foot look to see if there is a spot on the paper. No Spot lens not on. Un plug the CDR and try try Cleaning the lens with a cotton bud and some white spirt or glass cleaner and polish it after with another cotton bud
Dec 23, 2014 | Philips Audio Players & Recorders
Why does my philips cdr 570 mini recorder does not take blank cd torecord
Wrong type of disc (needs CDR or CDRW) or the laser lens is dsuty. Try a cleaning disc
Aug 31, 2014 | Audio Players & Recorders
My 570 CDR will not load a disc - it just keeps saying 'no disc' - whichever type is inserted either blank or pre - recorded. Any thoughts on this
The laser is either bad or has a dirty lens. Open the unit and inspect the lens - if it's dirty, clean carefully with a "Q" tip and alcohol. Turn the player on and see if it emits light from the lens and also observe it move up and down.
Nov 13, 2010 | Philips CDR570 CD Recorder
I have a Philips CDR 778 audio cd recorder. I try
you prbly need to replace the burning laser which i would imagine is still avail however the cost of the laser may not b a prblm but fitting it could b
Apr 17, 2010 | Philips CDR778 2-Disc CD Recorder
My problem is my phillips cdr 770 wont accept the cds that i bought they are maxell 80 min normal cd r but the recorder saying wrong disc use audio cd so what cds do i use ????? am stumped it should use...
THE PHILLIPS CDR 770 WILL ONLY RECORD ON "MUSIC" CD'S.I USE A MEMOREX MUSIC CD FROM WAL-MART, IT'S A 40X700MB 80 MIN, IT WORKS FINE, HOPE THIS HELPS, GOD BLESS, PAUL
Sep 29, 2009 | Philips CDR770 CD Recorder
I recently purchased a used Marantz CDR300 CD Recorder. Everything powers on but when I put a cd in the tray, it doesn't close automatically when I press the close button and when I manually close it, the...
CDR error means the trouble is in the laser eye,maybe the eye is faulty already or dirty. If the laser eye is dirty,then you need to clean it with a cotton buds.Open the unit then wipe the laser eye tenderly with the cotton buds or buy a DVD / CD cleaner kit.Just click this link;
http://electronics.bizrate.com/search__SEARCH_GO--GO__SEARCH_GO.x--36__SEARCH_GO.y--16__keyword--dvd+lens+cleaner__search_box--1__sfsk--1.html
Hope its help:
Regards;
VOTIT
Jun 27, 2009 | Marantz CDR-300 CD Recorder
Cd recorder stuck in Dealer Mode
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Feb 13, 2009 | Philips CDR795 2-Disc CD Recorder
Hi from greece,i have proplem with the philips cdr 770 i think i have to change the laser ( opu24.24) can we find it?
This has to be done by a certified technician as it is very tricky to get the laser aligned and requires special equipment.
Dec 20, 2008 | Philips CDR770 CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
PHILIPS CDR 606 RECORDER. I was useing the above machine till yesterday without any problem at all. Today i keep getting message "insert CD" after i have put a cd in.. I have tried differnt...
Either the optics have failed or the lens is dirty. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Basically the unit can not read the disk and is requesting that you insert one. If the cleaning fails to resolve the problem, you will need to have the optics replaced.
Dan
Jun 13, 2008 | Philips Audio Players & Recorders
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
