Question about Lenovo 03T8351 Motherboard Desktop Board Thinkcentre
I need a processor list for 03t8351 mb
It does not matter what size
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
Will windows vista 32 bit work on my HP ze5270 notebook/laptop?
look for windows vista minimum requirments here >>
Windows Vista Home Basic
Processor 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64)
System memory 512 MB - bytes (MB).
Note system configurations that use system memory graphics memory, at least 448 MB of system memory must be time operating system after some memory is allocated to graphics.
Card DirectX 9 class graphics
Graphics memory 32 MB - bytes (MB).
Hard drive size 20 Giga - (GB) in which the free space 15 GHz - (GB).
DVD drive internal or external
Internet access capability
Audio output capability
Apr 25, 2014 | HP Pavilion ze5270 PC Notebook
I want a dual core processor upgrade
You listed this under PC Laptop? It's a Desktop? Have you ever done a CPU upgrade? You are limited to what will work with your machine, Mobo and other components. Your Mobo is, of course, AMD compatible, so if you read the specs: http://support.acer.com/acerpanam/desktop/0000/Acer/AspireX1200/AspireX1200sp2.shtml The AMD Athlon X2 dual-core is best option. Memory is a easy option to increase speed a bit. Remember, with a 32bit OS the most memory it can use is 3.80 GB's More or Less. With a 64bit OS use more. I have done many CPU upgrades, you may not get the Speed/ processing increase you expect. After all, the components work in conjunction with one another. Do your research on Socket type, Pins, Power requirments, etc., etc.Check, Verify, then re-Check and re-Verify. Use this little freeware program to assist you, it list Spec info in detail, SPECCY at: http://www.filehippo.com/download_speccy/.
Jan 12, 2013 | Acer Aspire Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I dont have mother board driver for system model awrdacpi
The Intel® Desktop Board D915GAG supports one Intel processor in an LGA775 socket. See the table below for a complete list of supported processors.
Processors not specifically listed by type and rated speed can have requirements that are not supported by the design of the desktop board. Use of unsupported processors can result in improper operation, damage to the desktop board or processor, or reduced product life.
Processor Family System Bus Frequency L2 Cache Size BIOS Version Intel® Pentium® 4 800 MHz 2 MB 0391 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 2 MB 0401 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0477 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0283 or greater 800 MHz 1 MB 0209 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0244 or greater 533 MHz 1 MB 0475 or greater
533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater 533 MHz 256 KB 0283 or greater
DOWNLOAD LINK IS GIVEN BELOW...........
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22Intel+Desktop+Board+D915GAG%22
Sep 22, 2011 | Intel D915GAG Socket 775 Motherboard -...
Does my TOSHIBA SATELLITE 2805-S301 have a way to go wireless?
No wireless on this laptop you would need to use a usb wireless adapter
roduct Details and Features Product MPN MPN
PS280U-ELCLOH Key Features Laptop Type
Mid-Size Laptop Use
Home Use Processor
Pentium III 650 MHz Hard Drive
10 GB Display
14.1 in. TFT Active Matrix Operating System
Microsoft Windows ME Weight
7.3 lb. Processor Processor Manufacturer
Intel Processor Type
Pentium III Processor Speed
650 MHz Motherboard Bus Speed
100 MHz Memory Installed RAM
128 MB Max Supported RAM
384 MB Installed Cache Memory
256 KB Hard Drive Hard Drive Capacity
10 GB CD / DVD CD / DVD Type
DVD-ROM Optical Drive Read Speed
8x (DVD) Other Drives Floppy Drive
3.5" 1.44 MB floppy Display Display Tech
TFT Active Matrix Screen Size
14.1 in. Video Installed Video Memory
8 MB Audio Audio Output Type
Sound card Operating System Operating System
Microsoft Windows ME Platform
PC Technical Features Input Method
Keyboard Networking Networking Type
Integrated Network Card Data Link Protocol
Ethernet • Fast Ethernet Modem Modem Type
Modem Analog Modulation Protocol
ITU V.90 Battery Battery Run Time
2 Hours Battery Technology
Lithium ion Dimensions Width
12.9 in. Depth
10.7 in. Height
1.5 in. Weight
7.3 lb. Warranty Warranty
1 Year Miscellaneous Product ID
20789390 Family Line
Toshiba Satellite
Jun 19, 2011 | Toshiba Computers & Internet
Hello i need a new motherboard for my veriton 7700g can you please recommed one for me
Why do you want a new MB?
If you know the actual size or type of MB, I would suggest that you go to Newegg.com.
If I knew what you want the computer for, that will make a difference. You do need a MB that supports at least 2Gigs of RAM / memory. Most MB's now are PCI-e. You will have to buy parts like a vid card that is PCI-e built.
AMD is a rock solid processor. You can get a MB with the processor and fan alrady on it very reasonable.
Feb 19, 2009 | Acer Veriton 7700G PC Desktop
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Verbatim usb drive 8 gb help
Microsoft Windows 2000 help Processor:, Intel Pentium 133 MHz or equivalent 8 CPUs Supported. Memory:, 256 MB. Drives:, 1.0 GB Disk space CD-ROM / DVD drive ...
Computer questions and answers listing 200 - 299 CH000273, Not able to see over 8.4GB hard drive. CH000274, Not able to see or boot with hard drive over 33.8GB. CH000275, Unable to see over 8GB with ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Lenovo 03T8351 Motherboard Desktop Board Thinkcentre Logo
29 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
