Question about Jenn-Air Grilling
750-0142 jenn air burner replacement - Jenn-Air Grilling
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Posted on Sep 16, 2008
SOURCE: Jenn Air lp grill won't light with the ignitor button
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
Posted on Apr 20, 2009
  • 4736 Answers
SOURCE: How do you replace burners on Jenn-air 720-0337
First, remove the grill grates, then the flame tamers to access the burners. As you face the grill, carefully lift up the end of the burner farthest from you (It may or may not have a cotter pin holding it in. If it does, remove the cotter pin with a pair of needle nose pliers). As you lift it up, it should pull away from the burner orifice (inside the control panel). And that's all there is to it.To reinstall the burner, do everything in reverse. But, there is no need to replace the cotter pin. It was there for shipping purposes.
Hope this helped you. Please let me know. Happy Grilling!!
Posted on Jun 12, 2011
  • 4736 Answers
SOURCE: Do Jenn-Air have recommended suppliers?
Appliance Factory Parts http://www.appliancefactoryparts.com/ is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
Posted on Jun 26, 2011
Jenn Air halogen cooktop - front burner control turns on both burners
No,it's just a waste to have the two burners working at the same time in the first place!
May 04, 2017 | Jenn-Air Kitchen Ranges
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
Jenn Air gas grill model 720-0163 will not get above 180 degrees?
Try turning on just one burner to start, once it is on, turn on the next burner, if the flame gets lower on the first burner, you need to replace your regulator.
Dec 20, 2009 | Jenn-Air Grilling
My glass top with sealed burners Jenn-Air range is having trouble with the burners...the large burner does not come on at sall and the three smaller burners come on but do not maintsin the temperture...
Yes, you can fix this yourself! It is a simple repair thatyou canmake yourself, too.
The large burner needs to be replaced and the other burners need thr infinite swithces replaced on them.
I love the Jenn-Air brand ranges. Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will ship these parts to you overnight along with part removal/installation instructions for you to get cooking ASAP!
Thanks, Ella
Nov 16, 2009 | Jenn-Air SVE47100 Slide-In Electric...
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Jan 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Grilling Logo
64 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
