Question about Olympus Science & Laboratory
Olympus MX61L reapir - Olympus Science & Laboratory
LED display not lit
If you have the knowledge to reapir TV systems, go ahead,
One thing is sure: it won't get reapired by puhing remote control buttones
Aug 31, 2015 | Samsung Audio Players & Recorders
Got a quote to reapir an FLM-323B. Would not
Sounds a little high? look as long as you get a warranty on their work... What I do is ask, ring, around with the details you have now gotten, ask, say whats the cost to replace bla bla bla board on a bla bla bla TV? like doctors it always pays to get a "Second Opinion"
Feb 15, 2010 | Polaroid FLM-3732 Television
My neptune washer is making a loud noise when in th spin cycle like a bearing is going out. Is there a bearing going out?
unfortunately yes,
your main seal on the oter tub is drying out, and will continue to get louder until either the motor control fries due to resistance or it just seizes up
it can be reapired but you will need an new outer tub 500.00 spinner assembly 200.00 i could talk you through the reapir,, it really it that easy, but
for 700.00 you could easily replace the machine for brand new
i tell you this at the risk of a bad rating beacuse i bear bad new,, but i wanted to be as honest as possible to allow you an informed decision before you proceeded
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Switching on Xbox, redlight flashes on bottom
it means there is a internal error with your xbox,you must take it to get reapired,could be alot of different things,but it needs reapir
Oct 08, 2009 | Video Game Consoles & Games
Dropped my phone in water.need to get it reapired costeffectively
I dropped mine in water i pulled it apart (battery and battery cover off) and let it dry out for a day stuck it on charge and it worked again.
Dec 22, 2008 | LG Prada KE850 Cellular Phone
Samsung HL-S5087W DLP picture is distorted
If the picture is distorted it probably needs reapir. I recommend doing a little research to find a reputable reapir shop. You can ask where you bought it or where they sell TV's. If you get two answers the same it might be worth talking to them for pricing.
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
I want to reapir my camera please explain
I don't have a repair shop , I work for an electronic repair shop
so you should look for a repair shop near you and take it to them
Oct 16, 2008 | Video Cameras
Olympus mju 410- Orange lamp flashing
I had this happen and fixed it by removing the battery and leaving it out overnight and making sure it was fully charged - the next day battery inserted and it was ok. Prior to inserting battery I opened shutter cover and help down shutter release to try to drain any residual power. - Worth a try.
Oct 12, 2007 | Olympus MJU 400 Digital Camera
No flash
It is a problem that has happened to 2 out of 2 of my Stylus 410's. Olympus will not reapir them unless they are under warrenty (or for $175). I filed with the BBB...we'll see if that helps. They really need to recall them. Good luck. =)
Aug 09, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Science & Laboratory Logo
Top Olympus Science & Laboratory Experts
Are you an Olympus Science and Laboratory Expert? Answer questions, earn points and help others
