Fault code f34 balay TS 8416 washing machine
Cannot start or open door
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
SOURCE: siemens s14.149 washing machine error
Mine was the front door catch!
Posted on Sep 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Posted on Jan 09, 2010
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima washing machine showing fault code
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Posted on Jan 27, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
Error E5 on Balay ts7210 washing machine
This is a door lock problem can be door lock or main PCB
Dec 20, 2013 | Washing Machines
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Bosch Washing Machines
My washing no start and display view f34 Thanks
The F34 code normally only occurs when you are trying to run the CLEAN WASHER cycle. The washer should be completely empty of laundry when you are attempting to start this cycle. If the washer is empty and you are trying to run this clean washer cycle then you could have a friction problem with the spin basket that is causing the F34 code. Try turning the spin basket by hand with the washer empty and dry. The basket should turn relatively easily. If the basket will not spin easily you could have a problem with the bearing in the back of the outer tub or you could have an item stuck between the spin basket and the tub inside the washer.
May 04, 2011 | Washing Machines
I have od on my control panel what does it mean
The OD "fault" code on the display means "OPENED DOOR". This does not mean the machine thinks the door is open, but it has not recognised that the door was opened prior to starting a wash cycle. This could be because you filled it, then turned it off before turning it back on to run the cycle. Often you can clear this "code" by simply opening and closing the door again and starting the wash cycle as normal. If this doesn't work then there may be a fault in the door lock switch or the control board.
Hope this helps.
Regards,
BElectric
Dec 01, 2010 | Maytag Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
