Question about Stairmaster Power Supply Kit with Plastic Output Connector | Domestic | Stairmaster
Replace switching power supply
Model no: fy1206000
No power at all
Common problem with this model. The power supply goes bad like emachines. Make sure the power switch on the back by the plug is turned on first. I have seen them powered on and still not supply power to the motherboard. For that model you need an ATX power supply replacement.
May 15, 2011 | Medion MD-1704 PC Desktop
My Codegen Switching Power Supply 350W Model 300Xi is smoking when I turn on my PC, a big cloud of white smoke when I turned it off.
There's obviously something wrong in the supply, but it's not worth trying to repair. Replacement cost of computer power supplies is so low that there's no reason not to just throw it away and install a new supply. The time spent in trying to troubleshoot the problem and cost of parts will certainly exceed the price of a new supply.
Nov 09, 2010 | AMD Codegen 350W ATX P4 Recommended...
I HAVE A MIRAGE MODEL NO. DR-B500E ATK 500W SWITCHING POWER SUPPLYIN MY COMPUTER AND IT HAS STOPPED OPERATING. I HAVE TRIED DIFFERENT POWER POINTS AND DIFFERENT POWER CORDS BUT THERE IS STILL NO POWER TO...
I recommend you replace the switch mode power supply. These power supplies have dangerous mains voltage inside the unit and you should not try to repair if you do not have electronic knowledge.
The cost of a 500 W ATX power supply should be approx. $100.
It is not difficult to swap out the power supply, make sure you have the power connectors are the same as the old power supply.
Nov 08, 2010 | Select Brands Mirage DR-B500E True 500...
On off switch on tower is not working need to replace
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Nov 12, 2009 | HP Computers & Internet
Current FSP300-60tha(1) psu needs to be replaced. Is there a recommended replacement model?
Is this a power supply in a desktop computer?
If so, any make ATX switch mode power supply will fit in the desktop case (the mounting holes are standard), just make sure the total output wattage is equal to or greater than the original unit. I suggest you remove the power supply and take it with you to your friendly computer shop when you purchase a switch mode power supply.
Oct 12, 2009 | Acer Computers & Internet
Dead Computer
Is the fan of the power supply still circulating?
If not, your power supply needs replacement.
Jul 24, 2009 | Okia 420w UL Approved ATX Computer Power...
Need to replace a Lite-on power supply witch came out of a Acer Aspire X1700 the power supply model # is PS-5221-06 need help finding replacement.
Yes, I see what you mean since your computer is an SFF, (Small Form Factor), and uses an SFF power supply. Hard to get a power supply replacement, much less the power switch for the power supply.
Some things to note about working on a personal computer power supply,
1.They use Electrolytic Capacitors inside them. The aluminum case, cylindrical looking objects. These 'Caps' are designed to slowly build up a charge, then release it all at once. They can hold a charge after being disconnected from power, for weeks, sometimes Months!
There are typically two large ones used in the Input Stage. These hold a LARGE charge! Touching the terminals on the bottom of a capacitor, or touching a circuit that they are in, can result in a bad shock, or even Fatal one!
2.The particular power supply you have, has a Soft Power On function built in. There is no switch cable from the front panel of the computer, to the power supply. The power supply can be plugged into power constantly, and needs no On/Off switch on the back. This switch could be removed, and the wires to it soldered together, with heat shrink tubing over the connection.
http://en.wikipedia.org/wiki/Computer_power_supply
http://en.wikipedia.org/wiki/Switched-mode_power_supply
You DON'T need an On/Off switch on the power supply.
I have given you a solution in the form of information, but am NOT recommending you open your power supply, Nor work on it.
Jul 22, 2009 | Lite On Computers & Internet
No pwr supply light on Pavillion desktop pc
Dec 20, 2008 | HP and Compaq Pavilion Replacement 200w...
I have an old e machine 500 (origional operating system was windows 98). I am replacing the ATX switching power supply , 230 wat, model lp6100a. My problem is connecting it. I know all the connectors...
The old AT power supply that these old computers uses has two six pin socket connectors and these are different to the ATX connector.
You cannot buy these power supply now, most likely you might find one/computer in a junk shop.
If you have electronic knowledge you might be able to cut off the connectors from the old power supply and connect it to the ATX power supply and modify the ATX power supply so you can switch on the power to the old computer. The old AT power supply uses a mains power switch whereas the ATX uses low voltage to turn on the power supply.
Good luck & have fun.
Nov 29, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Stairmaster Power Supply Kit with Plastic Output Connector | Domestic | Stairmaster Logo
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
