GE Top Load Washer Shuts off during wash cycle intermittenly
GE Model WHRE5260E1WW Shuts off intermittenly during wash cycle only // Repress Stsrt/pause button and cycle starts at 15 mins again can happen nurmerous times during wash cycle or not at all
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Ihave Bosch Maxx 6 e2 error. I tried to reset the machine but it didn't work. What is the problem and what can I do?
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
This worked for me
Jan 20, 2016 | Bosch Washing Machines
My Bosch max classic is showing error E2
http://www.fixya.com/support/t3342120-error_code_e2_mean_bosch_maxx
to fix you must do a master reset of the washing machine.
Aug 18, 2015 | Bosch Washing Machines
I have a bwm 50 washing machine displaying e2
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
My GE Washer continues to keep pausing during the wash cycle. After we push the button to restart it pauses again after 5 to 6 minutes and continues this throught out the entire wash cycle. We also went...
Please, check to insure that your washer is properly grounded. If you do not know what that means, call an electrician. Modern wash machines are controlled by circuit boards that operate on low voltage and are vulnerable to static electricity. Spikes or gaps in the electrical service from your power company could also be the problem. Your electrician should be able to help you with that as well.
Oct 05, 2017 | GE WSXH208A Front Load Washer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Turns off during cycle
well lets see what happens then reply to me
Jan 28, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
276 people viewed this question
Top Washing Machines Experts
