Question about Refrigerators
Loud fridge compressor stays on loud
When the fridge compressor comes on it stays on loud, does not quiet down
  • bwmac Feb 10, 2009
    I have a GE Profile side by side, two years old that has just started doing the same thing. When the compressor kicks on, it sounds like an air compressor in a mechanics garage. Is the compressor going out, or is it the run capacitor as the one gentleman suggested? How do I find out if it is the run capacitor? Can I check it somehow?
  • Marat Brikov Apr 03, 2018
    Most likely compressor motor is going out or there are oil issues in the compressor. This video is about oil change, but its slightly bigger compressor size, but same technique to do oil change. Good Luck!
  • 163 Answers
HI!!! You sem to have a problem with your compressor .The windings are going out..If the frig has a run capacitor change it and see what happpens.If it is still loud then you have compressor problem..Good luck..
Posted on Jan 22, 2009
LG LFX25991ST Linear Compressor Frig has started making a noticeable audible (vibrating?) noise.
There are instances where the compressor can come loose inside its housing. That is not an indication that it is going to totally fail and it has no effect other than the noise. The fan noise would be louder inside the fridge. It would be a squeal.
Jan 07, 2018 | LG Refrigerators
Avanti platinum wine fridge. Makes a loud sound when turned on. How can we fix it and quiet it down
This can be due to the compressor turning on and off. this is common in old wine fridges
Mar 17, 2017 | Avanti Refrigerators
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
I just bought a new frigidaire refrigerator. I plugged it in and it began to emit a large loud humming noise. It almost sounds like something is vibrating inside. Is this normal for a branc new fridge?...
It depends....it may be loud for a hour or so, but should quiet down as it cools...
There is an explanation for this, but it is very long and would involve intricate details about refrigeration systems...
If it does not quiet down after a 1/2 day then call the place where you got it and return it...
heatman101
May 10, 2011 | Frigidaire Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
There is a loud noise coming from my engine ..sometimes..
oh ok, you probably have air shocks and that is the compressor running... makes sense that it sounds with the engine off... it should not be a loud sound though, normally it's quite quiet and you only hear a faint noise... if it is that loud it's probably a bad compressor
Jan 13, 2009 | 2003 Lincoln Navigator
Refrigerators Logo
494 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
