Question about Acer Iconia W510-1422
My Acer Iconia W510 won't turn on
Power light is solid blue and the device is plugged in.
My 11 galileo pro tablet will not power on after charging for 9+hrs.. When plugged in the blue indicator light flashes..What is going on?
The blinking blue indicator may be reassuring you that charging is in progress when, in fact, the battery may be dead or the charger is defective.
Jan 02, 2017 | Tablets & eReaders
Tip
Kindle not charging
If your Kindle (any version) is not charging because the USB port has gotten loose, try this...wrap a small piece of aluminum foil around your USB connector - the end that plugs into the device. Be careful not to extend the foil past the end of the connector, you don't want to damage your device. Plug the cable in to the outlet and into the Kindle port as usual, then watch the orange light come on!
Kindle charging ports get worn out over time, the foil is a great conductor and makes a solid connection. Obviously, you'll want to try a different cable first, but if that doesn't work, this is free and easy!
on Mar 26, 2015 | Amazon Kindle Fire HD
How can I get it to turn on? fully charged
It might be the power button is faulty or the device is not fully charged.
Plug in a power cable and ensure the power light is coming on before trying to turn on.
Mar 12, 2016 | Ematic FunTab 2 7" Multi-touch Screen Kids...
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
Have been charging it for over 24 hrs it wont turn on?
If a little lamp is lit when you plug in the charger (indicating that the device is charging), then try holding the power button down longer until something appears on the screen. If no lamp is lighting when you plug in the charger then there is something else wrong. Check it is the right power supply for the device and that you are plugging into the correct hole of the device (not the earphone connector). It also may be the charger itself is not working.
Mar 05, 2015 | Tablets & eReaders
Why Is my kocaso tablet come on but blank back out?
I have the same problem with my KOCASO M9100 9" Black. I can tell it had power by the small LED inside that is blue when on but not plugged in, purple when on and plugged in, etc. But my screen is not working, I don't even get a hint of light from it on boot, and my computers cannot find it 95% of the time, the other 5% it detects the tablet as "Unknown Device", then when I click on the Device, it says its either disconnected or turned off. Cannot find a solution!
Jul 06, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
My kindle will not turn off. I can't get it to do anything.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still doesn't respond, do a hard reset by holding the power switch for 15 seconds
Jan 27, 2011 | Amazon Kindle Wireless Reading Device
My kindle does not to turn on when i slide the power switch
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 22, 2011 | Amazon Kindle 3G
Kindle 3g screen is blank can get it back on
Jan 17, 2011 | Amazon Kindle Wireless Reading Device
Travelmate C300
Sounds like it. . . (power pin problem). I use a Cable Retention Device like the one in this video to keep from damaging the fragile connector. . . .
Dec 07, 2007 | Acer TravelMate C302XCi-SP2 (TMC302XCISP2)...
Acer Iconia W510-1422 Logo
545 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
